Power steering fluid
Old Mar 3, 2010 | 05:25 PM
rodneywar's Avatar
rodneywar
I am upgrading my truck's steering system as well as adding a hydro boost too. also i am removing my factory cooler for the P/S system and adding a tranny cooler in its place. I know it might be overkill but makes me happy lol. My question is should i run what the factory says power steering fluid or should i use ATF in its place? thanks
Old Mar 3, 2010 | 05:39 PM
starmilt's Avatar
starmilt
I think I would go with the power steering fluid. What does the superdutys call for.
You might look at the specs on the power fluid and different hydraulic fluids and get some better prices in gallon jugs.
Old Mar 3, 2010 | 06:01 PM
rodneywar's Avatar
rodneywar
I have no ides what the superdutys call for i am still trying to search fluid specs
Old Mar 3, 2010 | 06:05 PM
starmilt's Avatar
starmilt
The reason I said super duty or it might be F450 something the hydroboost comes in.
Old Mar 3, 2010 | 06:12 PM
rodneywar's Avatar
rodneywar
yep the hydro boost system is coming out of a 1994 F super duty aka F450
Old Mar 3, 2010 | 06:24 PM
rodneywar's Avatar
rodneywar
Still no luck!!
Old Mar 3, 2010 | 06:53 PM
drewdole's Avatar
drewdole
i have to say i do add atf but power ster fluid is better as my mech. buddy tells me, but im just a 93 stock 7.3 4x4 e4od.
Old Mar 3, 2010 | 07:45 PM
rodneywar's Avatar
rodneywar
I wonder if P/S fluid is just hydraulic fluid???
Old Mar 3, 2010 | 07:50 PM
starmilt's Avatar
starmilt
I am not sure that is why I wanted you to look up the specs, so we would know. lol
All hydraulic is not the same, I am thinkins some might be.
Old Mar 3, 2010 | 10:03 PM
rodneywar's Avatar
rodneywar
http://www.pennzoil.com/documents/Po...eringFluid.pdf
and based on a few pages on fte type F atf is the consensus here
Old Mar 3, 2010 | 10:08 PM
LCAM-01XA's Avatar
LCAM-01XA
The correct fluid to run in that system is Ford Type-F auto trans fluid. I personally run Dex/Merc-III in mine so it's the same as what lives in the E4OD (one less bottle to carry around), I've done this with all my Ford and GM vehicles regardless of hydroboost or not and never had a problem with it, but some people say the Dex/Merc-III ATF makes their pumps a bit louder than when they run the Type-F ATF. Anything labeled as "power steering fluid" generally does not belong in your power steering system.
Old Mar 3, 2010 | 10:09 PM
87crewdually's Avatar
87crewdually
FWIW when i replaced my pump it specifically said on it to use P/S fluid only or it would void warranty. But originally the system was ATF along with pratically every other Ford I've ever worked on.
Old Mar 3, 2010 | 10:10 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I am running synthetic power steering fluid in mine.
Old Mar 3, 2010 | 10:14 PM
mechelement's Avatar
mechelement
My superduty calls for ATF. IIRC, fully synthetic ATF.
jmuenchow
Jun 24, 2017 11:22 PM
4byford
Mar 14, 2017 08:01 AM
cyclone-429
Jul 24, 2016 03:04 PM
rv7plt
Nov 13, 2015 01:45 PM
Enomra
Jul 10, 2012 01:08 PM
