Sponsored by: Real Truck
Harley Davidson headlight upgrade
Old Mar 7, 2010 | 03:59 PM
Futuresweets-10's Avatar
Futuresweets-10
Originally Posted by camodown
You can upgrade your wiring harness to supply closer to battery voltage to the bulbs but that is all I would do. Some people go with higher wattage bulbs, but those tend to heat up the terminals and melt the housing. Additionally, there are mods to make the high and low beams active at the same time which can also overheat the bulb. In short, the 9008 bulb design leaves MUCH to be desired with respect to being heavy duty. Another thing you will not want to do (In my opinion) is go with Sylvania silverstars. The wattage is the same as stock but yet they talk about increased light output. For some reason this makes no sense. If you look closely, the bulb is coated, instead of being clear. This acts like a 'filter' and only allows whiter light to be emitted. While yes, it "looks" brighter, actually it isn't. Additionally, in inclement weather, and night driving, you want light more on the yellow side as it helps with perception. In other words, keep the stock bulbs in there, or go with clear replacements if you ever need to. Dont upgrade the wattage, and if you want, get a headlight harness to up the voltage. The 9008 bulbs like battery voltage. Don't even get me started on HID retrofit kits... Those are not designed for the housing and while yes, it may *seem* like they light up better, you are just blinding oncoming traffic. Filament headlight housings are designed for filament lightbulbs, NOT HID. Now of course, I am probably going to get a bunch of people angry, but oh well.... hahah
You are wrong!!! They make HID bulbs so that must mean they HAVE TO BE OK!!!! YOU DONT KNOW WHAT YOU ARE TALKING ABOUT!!!!!......
J/K... Ive always had the same belief as you on HID's in reflector housings and still believe this to be true; however, I installed HID's in mine a few months ago and I dont dislike them as much as I thought I would. At first the light seemed 10x better and it was easier to drive at night, but once I got use to them they arent such an improvement. I think the biggest reason I noticed a large improvement is because my passenger side bulb socket was corroded before the conversion and it made that light so dim it was practically not on. The only reason I installed them is because I sell alot of them and it just looks better to be useing something I sell.
Old Mar 7, 2010 | 04:45 PM
RentAMan's Avatar
RentAMan
Talking
bosshoss...
Were you able to find that diagram in order to cut out the header panel?
Anyone out there have that diagram to install the 07' headlights in an
99'-04'???
Please email me at jlanger70@yahoo.com
Old Mar 7, 2010 | 06:30 PM
camodown's Avatar
camodown
haha. It really is a shame that the HID kits don't have the required assembly to be a full on retrofit into traditional reflector headlights because I would be all for better lighting. The 05+ lighting is junk if you drive at night frequently. I find I use my auxiliary lights often (when there no traffic of course) in order to see where I am going. Shoot, the lights in our Explorers stomp all over the lights in the F-350. Those turn night into day. At any rate, while HID systems are nice, aftermarket kits don't change the assembly to allow for a distinct cut off, and glare oncoming drivers like crazy... At least the ones I have seen do. NOW, if they would only design an HIR kit, then hmmm that might be worth looking into, but oh well. I guess I'll stick with the worst bulb design ever...
Old Mar 7, 2010 | 07:04 PM
camodown's Avatar
camodown
http://www.puredieselpower.com/Tech/...Conversion.pdf
^ There is a link with pictures for whoever was looking for it!
Old Mar 7, 2010 | 08:32 PM
Boss_hoss's Avatar
Boss_hoss
heres what i started with, the red lines are where I had to cut more
[/IMG]
Old Mar 8, 2010 | 03:04 AM
RentAMan's Avatar
RentAMan
Talking
bosshoss...
Can you possibly email the whole article to me at jlanger70@yahoo.com
I would love to see what it has to say about it.
And of course the pictures to use as a template.
Old Mar 8, 2010 | 07:59 AM
Citypol86's Avatar
Citypol86
...The 05+ lighting is junk if you drive at night frequently. I find I use my auxiliary lights often (when there no traffic of course) in order to see where I am going. Shoot, the lights in our [fill in your favorite vehicle that you can actually see from at night] stomp all over the lights in the F-350...
I couldn't agree more. What I really miss are the Hella quartz reflectors with 130 watt high and 100 watt low beams. They have the "European style" cut-off so they don't blind people, you can see so much better but they are replacement for a standard sealed beam.
Later...
Brewster...
Old Mar 8, 2010 | 12:22 PM
C-TAN's Avatar
C-TAN
Nice upgrade! I may need to do that.
Old Mar 13, 2010 | 03:28 PM
Citypol86's Avatar
Citypol86
Originally Posted by Citypol86
I just picked up the pigtails. They're $10 and change from AMAZON.COM. They're made by Halo Automotive, P/N WH9007...
I just realized my mistake, you [and I] need 9008 connectors not 9007. I'll be returning the Halos.
I hope I didn't screw anyone up with this.
Later...
Brewster...
Old Mar 26, 2010 | 09:53 AM
R3AP3R's Avatar
R3AP3R
Ok so I have a question on this subject. I have a 2005 XL f-250 and i'd like to upgrade from my sealed beam headlights currently on it. I also want to go with the harley lights. But being a 2005, would I still need to do any trimming for them to fit? I plan on using this upgraded wiring harness Upgraded Headlight Harness for 05 up Ford With 9008 Bulbs to convert for the 9008 bulbs, but all I really want to know is if I can just order the oem Harley lights and simply bolt them in? Thanks in advance for any light you can shed on my question.
Old Mar 26, 2010 | 11:24 AM
Furian's Avatar
Furian
You Keep What You Kill
I'm doing the same upgrade and from what I've been told, no cutting is required.
Old Mar 26, 2010 | 06:34 PM
R3AP3R's Avatar
R3AP3R
Ok. Thank you.
Old Mar 26, 2010 | 09:18 PM
  #28
YoungMT Hick's Avatar
YoungMT Hick
ok so mine is a 06 but i did a custom job to mine didne like the harley ones but i wanted black ones here is it
any questions just ask
Old Oct 27, 2010 | 10:31 AM
  #29
Hoofbeat's Avatar
Hoofbeat
Boss Hoss, love the headlight upgrade
YoungMT Hick, where did you get your grill? That thing is sweet!
xcrunner2616
28
Dec 23, 2023 10:03 PM
nyaristo
Nov 7, 2010 07:42 AM
alittle40
1947 and Older Ford Trucks
Oct 22, 2010 11:18 AM
71-4R3SONS
Nov 25, 2007 09:32 PM
BigRalph2000
19
Aug 21, 2007 08:57 AM
