SWAP
Old Mar 2, 2010 | 07:04 PM
maverickfe390's Avatar
maverickfe390
SWAP
Hey everyone this is what I would like too do I have a 1967 F-100 4X4 with a 390 it has a 4 spd in it right now what I would like is too put in a C6 that I got from a pull and save I will be rebuilding the trans if I can do this.I do have the transfercase that went with the C6 too.And I do have the the bracket that went with it.Would this work Idont see any trouble in doing this but has anyone done this?And if so what did they do and what was needed?
Thanks
Scott
Old Mar 2, 2010 | 07:21 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
C6s were made with many bolt patterns on the bellhousing. Did you get one that will bolt to a 390? This trans could be had with a small block, FE, big block, or diesel bolt pattern. They are not interchangeable.
Old Mar 2, 2010 | 07:42 PM
maverickfe390
I pulled it from a 390 4X4 pickup I think it was an 74 or so.
Old Mar 2, 2010 | 08:59 PM
Mark Kovalsky
Then it should work fine. You'll need to connect the vacuum line to engine vacuum, not ported vacuum. You'll also need to connect the kickdown rod to the carb.
Old Mar 3, 2010 | 10:17 AM
maverickfe390
Hey thanks mark can i email you if i have any trouble with this i am rebuilding it too
Old Mar 3, 2010 | 10:47 AM
Mark Kovalsky
You can, but I am not a C6 expert. I've never worked on one.
Old Mar 3, 2010 | 12:19 PM
Lazy K's Avatar
Lazy K
Free c6 repair manual - .Pdf & Word Free Ebooks Download This may or may not help you. Either way it`s free.
maverickfe390
Apr 8, 2010 07:14 PM
snsgraham
Modular V10 (6.8l)
Nov 3, 2005 06:37 PM
Scott 02Eddie
May 9, 2005 02:45 PM
seaves46
Dec 3, 2004 03:26 PM
