Sponsored by: Real Truck
transmission problems
Old Mar 2, 2010 | 05:02 PM
speednracer's Avatar
speednracer
My trans will not go in reverse or do i have high gear. 2004 super duty V10 4X4.
Old Mar 2, 2010 | 05:58 PM
A H DEVELOPMENT's Avatar
A H DEVELOPMENT
Welcome to FTE, speednracer!!!!!!!
Old Mar 2, 2010 | 05:59 PM
A H DEVELOPMENT
Auto or Manual?
speednracer
Thank you!
Old Mar 2, 2010 | 06:01 PM
speednracer
It is a auto
Old Mar 2, 2010 | 06:16 PM
A H DEVELOPMENT
High gear???? I assume you checked fluid level and fluid condition? Is reverse totally gone? Any noise when you shift to reverse? Are all other gears engaging and working properly?
Old Mar 2, 2010 | 06:30 PM
speednracer
yes i check the fluid levels and condition. A little noise when you put it in reverse but thats it . Everything else works fine. I can drive it down the road just not in high gear. I think i saying high gear correctly maybe . It will go forward in only 1 gear.
Old Mar 2, 2010 | 06:32 PM
speednracer
Sorry im not to good at decribing things.
Old Mar 2, 2010 | 07:00 PM
Fishin76's Avatar
Fishin76
Which gear would that be? D , 2, or 1 on the column?
Old Mar 2, 2010 | 08:22 PM
speednracer
Well i can put it in any but it won't change out.
Old Mar 2, 2010 | 09:52 PM
Fishin76's Avatar
Fishin76
So it will not shift out of 1st gear, and you don't have reverse, correct? Sounds like your in for a rebuild.
Sorry to be the bearer of bad news......
Fishin76's Avatar
Fishin76
Does your speedometer work? If not, you may have a bad speed sensor. Does your overdrive light flash?
Old Mar 2, 2010 | 11:03 PM
rockstate45's Avatar
rockstate45
How many miles?
Old Mar 3, 2010 | 12:11 PM
A H DEVELOPMENT
Are you saying that the transmission will not shift automatically in the forward drive gears and no reverse at all???? If so could be the CPU that controls the electronic shifter. Oh wait a minute, you have the 4R100 4spd or TorqShift 5spd???????
Old Mar 3, 2010 | 06:30 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is no electronic shifter on either the 4R100 or the TorqShift. Both have mechanical drive or reverse engagements. He has a 4R100.
There is something mechanical broken. There is nothing electronic that will keep it from engaging reverse.
