I just got my 300 finished and running good but it is time for the transmission. I have been thinking of rebuilding it. It is a 3 speed manual, use to be on the tree but have it converted to floor. It is in a 1975 ford F100 shortbed 2wd. It is mostly a weekend cruise around truck, I have to run super and gas mileage is really not an issue. I was wondering what the best transmission would be for my set up. I want to keep it a manual. Maybe more of a cruising transmission. I would like to put a 4 speed in but, I think all the truck ones are granny gear first. I really dont know that much about the transmisssions and compatiability. I think my rear end is 3.23 or something of the such. any information would and could help thanks
"Cruising"? As in driving around the highschool, or driving long distances?
If you reconsider an automatic:
C4
C6
AOD (has OD)
Manual:
The 4 speed granny low truck transmissions.
The 4 speed OD transmissions used late '70s to mid '80s. (4th is OD)
The 5 speed OD Mazda transmission used '87 and up behind the 300 in half tons. (uh, requires hydraulic clutch...)
The 5 speed OD ZF HD trans used '87 and up in 3/4s and up. (same juice clutch issue)
The 4 speed toploader performance trans from the mid '60s to early '70s. First will be a little tall, (2.78) but the gears are close and they shift real purdy....
The 5 speed OD T5 trans from a V8 Mustang. Requires adaptor or different bell.
I guess cruising wasnt the right word, sorry. probably more for performance. I actually would like a taller first gear.The way I feel is my first gear right now is a little low, second is perfect and 3rd seems to tall. It works but I guess I thought I would ask on here before rebuilding the 3 speed. thanks
