1969 power steering
Old Feb 27, 2010 | 10:53 AM
Slip ford man's Avatar
Slip ford man
1969 power steering
I was wondering what options there are to change (run a new style pump) the location of the power steering pump on the c9ve 69 block. Anyone here with knowledge on this...thanks
Old Mar 3, 2010 | 02:36 PM
mcdonaldm's Avatar
mcdonaldm
not sure exactly what you are asking. do you want to do away with the old style pump and run a newer style one in the stock location? do you have the style that fits behind the balancer? if so then nothing but that style.
if it is a belt driven one then what i did on the 460 i got from a 70 Lincoln was to use the stock brackets and just bolted a newer style Pump (actually from a mid-70s mustang II as i was using the rack from same car, this way i was sure the pump pressure matched the rack requirement). it uses the same 3 bolt pattern as the old style pump. you just have to remover the pulley to remove it from the old bracket.
another thing to watch for is that the early T-bird engines used a shorter water pump, so not sure if this affects the pwr pump alignment or not, so check alignment first.
rgds
Mike
Old Mar 5, 2010 | 04:04 PM
Slip ford man
Thanks Mike
Roger C
Feb 16, 2017 09:57 AM
Jacks 65
19
Aug 10, 2016 09:30 PM
Cjohnson80
Jun 16, 2016 08:27 AM
robjs111
1978 - 1996 Big Bronco
May 6, 2013 11:43 PM
Jeff-150
18
Feb 4, 2008 07:52 PM
