So I am driving my truck and BAM it dies. I have been having some issues with my battery and such. What would cause the truck to just suddenly die? I am really just wanting to get this truck running so I can drive it! Help me out please! I have been getting 14.3 volts at the battery while it runs and right around 12 volts when its off. Any thoughts?
It was turning over slowly and then the solenoid started clicking. If I get it jumped it will start up. Not sure if the coil is the problem. Do we think it could just be a bad battery?
Bought a new battery and BAM! Its good to go. I took it in a got it tested elsewhere and they said it was bad. Now I have 13.86 volts after running and 14.4 volts while running.
HOWEVER......now I think I have a fuel issue. How do you diagnose a fuel issue. Basically when I get on an incline my truck will die. I had to roll it back down the hill and it takes a few minutes to get started back up. I am going to get a new filter and replace that and maybe the fuel pump. What do you guys think?
You're saying that it'll die on a hill when running right? If it won't run after being parked on a hill then you might be losing gas to the carb in the fuel lines. I've had this problem.
