Injector Hold Down Bolt Size?
Old Feb 26, 2010 | 06:15 AM
wolffee's Avatar
wolffee
Question Injector Hold Down Bolt Size?
Getting ready to pull an injector in my 6.0 had on fail on me. Being a mechanic myself mainly marine Detroits and MTU's I feel it should be no problem. However my mechanic friend said its no big deal as long as you have a long shank torx to reach the hold down easier. He couldnt remember the size. Does anyone know so I can have it before I start the job...
Thanks
Ryan
Old Feb 26, 2010 | 06:58 AM
bismic's Avatar
bismic
Long shank Torx (apprx 3 inch)
IIRC - T40 socket for early model years (production prior to 9/29/2003) and T45 for commonized engines (commonized began in 2006).
Unbolting the oil rails requires a T30.
Here is a good FTE thread if you are interested:
https://www.ford-trucks.com/forums/5...ml#post4355612
Old Feb 26, 2010 | 08:28 AM
wolffee's Avatar
wolffee
THANKS FOR THE INFO THE SNAP-ON MAN HAPPEN TO COME TO MY SHOP TODAY AND I WAS ABLE TO PICK UP A T-30 LONG SHANK. SHANK TO TIP IS 3 1/2 IN SO THAT SHOULD WORK. BUILD DATE ACCORDING TO THE VINN WAS 10/20/03. THANKS FOR ALL YOUR HELP AND I WILL DEF CHECK OUT YOUR LINK WHEN I GET SOME GOOD TIME...
RYAN
Old Mar 5, 2010 | 10:58 AM
cricketmowing's Avatar
cricketmowing
6.0l and biodiesel
Does anyone use bio diesel?
Old Mar 5, 2010 | 01:41 PM
lovntexas's Avatar
lovntexas
I believe it's t40.
mcali2
Jan 30, 2017 10:08 PM
Restlesswildman
Sep 13, 2014 10:04 PM
jsavin
Jan 19, 2013 02:16 PM
fast70
Oct 13, 2010 10:53 PM
AndeyHall
Mar 3, 2010 08:41 AM
