Water injection
Old Jan 20, 2003 | 11:04 PM
fordxxx's Avatar
fordxxx
Talking Water injection
Have any of you guys ever heard of water injection in a gas engine? I think its to stop detonation in hi compression engines. How does it work?
Old Jan 20, 2003 | 11:51 PM
BB's Avatar
BB
Water injection
About 20 years ago I played around with a Spearco (sp) water injection system on an old Triumph Spitfire that I bumped the compression a little too high.
I believe the main effect of water injection is to reduce the peak cylinder pressure, but increase the average cylinder pressure, during combustion. As the water droplets are heated they absorb heat, slowing down the initial rate of increase of temperature (and so pressure), but once they are steam then they are providing more gas (in effect) to push on the piston, so the expansion process is more efficient.
Again, it's been a long time since I took physics, could be full of it!
This might be a better topic in the general engine forum.
Barry
Old Jan 20, 2003 | 11:59 PM
Mil1ion's Avatar
Mil1ion
Water injection
Go to the Lightning forum and read about the Water Cooled fuel injection on the upcoming 500 HP engine.
I'm sure that is what you are talking about!
Old Jan 21, 2003 | 01:41 PM
Matt67's Avatar
Matt67
Thumbs up Water injection
I used to play around with 6-cyls, and whenever we were talking about water injection, it was heated water from the engine going though a special manifold, or a plate under the carb. 6-cyls have a problem that when you put headers on them, the carb gets to cold and turns the gas into drops istead of a spray.
In V-8's the problem is oposite and the carb usually gets hot, so i think a water injection on a V-8 would be cooled water like with the post about the Lightning.
Old Jan 21, 2003 | 02:28 PM
BB's Avatar
BB
Water injection
Matt, that water-cooled carb. spacer does a couple of things for the inline 6. When the weather is cool and damp the heated spacer helps keep the carb. from icing. When the weather is hot the spacer helps keep the carb. from vapor-locking from the exhaust heat riser. Sort of like a temperature stabilizer. Interesting huh?
Barry
beartracks
Jun 29, 2016 04:33 PM
beartracks
Jun 23, 2016 12:21 PM
scottperkins
1997 - 2003 F150
Jun 5, 2016 10:07 PM
wtx66f100
May 23, 2015 09:14 AM
doop
Sep 16, 1999 09:11 PM
