had to limp home/speedometer bouncing
Old Feb 24, 2010 | 05:08 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Exclamation had to limp home/speedometer bouncing
i had to limp home due to a short? speedometer bouncing.
yesterday,i noticed my speedo would peg over to 0 when i hit a bump.i didn't think much of it.figured a connection must need cleaning.
so today after work,i load up with brush and head home.about 7 miles from home,i notice the speedo really going crazy (it's raining today.)
then i thought to myself,if this keeps up,my trans is going to downshift(due to the electronically controlled E40D).well sure enough the needle started staying pegs at 0 mph long enough for the trans to keep searching between 3/4,so i said ok,il turn off OD.this worked for a mile,until it got worse.i had to slow down to 30 mph because it was starting to search between 2/3 and i didn't want it to rev to high of course when she hit number 2 lol.
so.......the question is.whats wrong? and what do i look for first?
thanks guys!
Old Feb 24, 2010 | 05:26 PM
johnboggs21's Avatar
johnboggs21
The sensor in the rearend mighta went out on ya
Old Feb 24, 2010 | 05:58 PM
starmilt's Avatar
starmilt
If my tranny ever does that I'm gonna slap the chit out of whoever is rideing with me. lol
Check and see if your epump is pulling too many amps. lol
Old Feb 24, 2010 | 06:20 PM
boots6868's Avatar
boots6868
I had the same thing on my 96 with e40d and it was the rear end speed sensor. or vsp vehicle speed sensor cost me 160. at the dealer. yep the speedo was all over the place and it couldnt find the right gears darn near put you through the window. Good luck
Old Feb 24, 2010 | 06:43 PM
FORDF250HDXLT
LMAO!
well,let's hope it's not a big deal.
my e-pump only draws 2 amps star lol.
ok guys.thanks a mill.going to check into it.
Old Feb 24, 2010 | 06:51 PM
FORDF250HDXLT
so is this what i need?
rockauto.com
1993 FORD F-250 7.3L 445cid V8 DIESEL MFI (M) : Electrical : Vehicle Speed Sensor
DORMAN Part # 970012 More Info {OE Solutions}
Rear
$10.27
testing direct link (it's cool right? they are a site sponsor last i knew?-i cant see the adds anymore since becoming a supporter.sorry mods if im wrong.)
RockAuto Parts Catalog
hmm.doesn't seem to work anyway.
least ya can see how i got there from the description above.
10 bucks hey? i think i can handle that.
Old Feb 24, 2010 | 07:37 PM
FORDF250HDXLT
ok,my local autozone appears to have one in stock.
duralast part # SU1019
like 30 bucks.
id like to do this of course,as i can drive over 30mph sooner lmao
someone tell me if im on the right track here?
Old Feb 24, 2010 | 07:40 PM
fast70's Avatar
fast70
thats it but i also had to clean all the conections to the speedo on mine they were dirty because truck had bad window seal leak but its all fixed now
Old Feb 25, 2010 | 04:55 PM
FORDF250HDXLT
ah,easier fix than expected.i didn't need to replace it.
the ram to my dump had chafed the wires to the VSS.so i just had to repair the line and wire tie it back out of the way.
that explained why it did it mostly on bumps lol.the ram would come down and pinch the wires.there's two wires,and one of them was just about cut right off.she wouldn't of went much further,other than slow in first gear haha.
anyway.back in action.false alarm kinda.
now to build a little block for the rear of the ram to sit on.i see it's just starting to wear into the rear diff cover/very top lip of it.so don't wont this.
Old Feb 25, 2010 | 04:59 PM
fast70's Avatar
fast70
glad to here thanks for letting us know your solution
Old Feb 26, 2010 | 02:29 AM
Sycostang67's Avatar
Sycostang67
If you want to make sure this doesn't happen any more, you could swap in a MANual transmission.
automaticlee
Feb 19, 2017 01:39 PM
cv18sro
1997 - 2003 F150
Dec 7, 2015 07:50 AM
52 F1 Stocker
Oct 21, 2015 08:20 AM
GeneGregory
Sep 15, 2015 05:15 PM
inalabama
13
Aug 17, 2013 01:55 PM
