Sponsored by: Real Truck
Performance Y pipe...
Old Feb 24, 2010 | 08:41 AM
Jayman1's Avatar
Jayman1
Has anyone bought one of these? If so does it work as described with the added HP and torque?
http://cgi.ebay.com/ebaymotors/00-04...Q5fAccessories
Old Feb 24, 2010 | 09:59 AM
KhanTyranitar's Avatar
KhanTyranitar
Yes they work great, recommended upgrade.
Old Feb 24, 2010 | 10:05 AM
SuperDutyScaler's Avatar
SuperDutyScaler
yes i bought one too is does help but after seeing it now on my truck i would just go to a exhaust shop and have them make me one that looks better for the same price. when i get ready to put a bigger cat back on my truck for towing im going to get the exhaust shop to redo it
Old Feb 24, 2010 | 12:34 PM
bryyce62's Avatar
bryyce62
I have one. I gained between 1-2 mpg by installing it. Don't know if there are any gains in torque and/or HP but it feels a little more pep. I recommend it.
Old Feb 24, 2010 | 12:57 PM
chris60's Avatar
chris60
00-04 Ford F250-F350 6.8L V10 Performance Y Pipe : eBay Motors (item 220557297423 end time Feb-25-10 15:35:36 PST)
everything you will ever need to know about the Y-pipe - it's all good
https://www.ford-trucks.com/forums/8...-2v-dynod.html
Old Feb 24, 2010 | 03:44 PM
1975StroppeBaja's Avatar
1975StroppeBaja
I'm going to be installing the y-pipe on mine this spring. I've read nothing but good things about it.
Old Feb 24, 2010 | 05:20 PM
Sand_Man's Avatar
Sand_Man
Just curious, but where'd you get it and are your MPG gains freeway or combined? Either way, that's enough of a reason for me to get one. Thanks, Jim
Old Feb 24, 2010 | 05:42 PM
bryyce62's Avatar
bryyce62
Sand_man,
I got the same one that is in the first post, from the same seller. He had a different name. But it came from the same city in Oregon. It'll fit a 5.4L or a 6.8L. Regarding the mileage, it is mostly freeway, but even then I'm usually 5-10 over the limit.....if you know what I mean.
I put a cat back exhaust on my rig back in '03 but didn't realize at the time there was that pinch point in the factory exhaust. Took me 5 years to realize that the y-pipe what it needed all along. One of those....'wish I knew then what I know now' things.
Get it. You won't be sorry.
Old Feb 24, 2010 | 05:44 PM
SDTriton250's Avatar
SDTriton250
Ford must have REALLY made some changes to the newer ones. Mine looks nothing like the picture of the stock Y pipe. Mine has large pipes and two big cats before the Y collector. My Y collector looks more like the new one pictured. Is that factory Y pipe pic real? I looks like an exhaust sine wave nightmare!
Old Feb 24, 2010 | 06:13 PM
1975StroppeBaja
Unfortunately, that y-pipe pic is real.
If someone had made a bolt-on version I would've done it by now. But since I'll have all that apart this spring, I'm gonna weld one in.
Old Feb 25, 2010 | 07:19 AM
Jayman1's Avatar
Jayman1
As usual, lots of good needed info from my fellow FTE's. Looks like I will also be buying one this spring but I don't have the luxury of a welder nor would I be very good at it. Maybe someone in the Fremont N.H. area could help me out. I just installed a K&N FIPK on my truck yesterday morning, I have a Superchips Cortex Tuner coming today via FedEx and will look forward to tuning it out & I should be getting my new sway arm bushing set from Amazon on Friday and I can install that maybe over the weekend if not sooner. I made enough room on one side of my garage so that I can pull the front end of my truck in to be able to work on it if needed. So hopefully with the K&N FIPK, the tuner and the Y pipe I hopefully wont have to have my foot so far into the pedal to get rolling. I wonder what total HP I may gain all together?
Old Feb 25, 2010 | 12:18 PM
Jayman1's Avatar
Jayman1
Sand_man,
How is the quality of the metal one from e-bay? Does it appear to be holding up well? How long have you had it?
Old Feb 25, 2010 | 02:34 PM
bryyce62's Avatar
bryyce62
I've had it about 18 months or so. Seems to be holding up just fine.
Old Sep 16, 2010 | 07:36 AM
BEAST428's Avatar
BEAST428
I have a 2003 Excursion 5.4 and have just started looking for a Y pipe when I found this post. The e-bay ad is gone. Does anyone know where I can get it???
Old Sep 16, 2010 | 09:05 AM
redford's Avatar
redford
FTE Leadership Emeritus
On eBay!
00-04 Ford F250-F350 6.8L V10 Performance Y Pipe : eBay Motors (item 220666169959 end time Sep-17-10 14:54:04 PDT)
kellysguy
Jan 28, 2016 08:46 AM
BEAST428
Modular V10 (6.8l)
Sep 27, 2012 12:04 AM
gino
Feb 17, 2012 01:20 PM
10strokin
Modular V10 (6.8l)
39
May 22, 2006 07:45 PM
BC478
Jun 1, 2005 09:08 AM
