SMOG PUMP
Old Mar 4, 2012 | 01:25 PM
  #46
Bankrupter's Avatar
Bankrupter
Originally Posted by Bankrupter
LOL I didnt even knew they made it. Only Ford Racing idler I knew off was the A/C delete - P/S relocate bracket or Idler depending on year. Look forward to your update
bump for update
Old May 2, 2012 | 06:11 PM
  #47
70torino429's Avatar
70torino429
Dont know what im doing wrong, got the 96.08" belt and its just too short
Old May 2, 2012 | 08:43 PM
  #48
Scndsin's Avatar
Scndsin
Don't know, but the way I have it routed, is actually backwards around the tensioner. I had to pull it up to its full range of travel & then slip the belt opposite of how it normally rides on the wheel & release. ( If that makes sense) Can you try that? Then again, maybe that length is just not adequate for your particular year & its slight differences.
Old May 3, 2012 | 11:36 AM
  #49
70torino429
Ill give it a look over again after work but i have the same pulley/tensioner setup as in your pic. 94 f250 351
Old May 3, 2012 | 11:47 AM
  #50
Scndsin's Avatar
Scndsin
Well there are some minor diffs tween the 250/150 as has been pointed out to me on more than one occasion. This might be another. I can describe the rope trick I used to measure for it if you can't get tension.
Old Jun 30, 2012 | 09:44 PM
  #51
BleedingBlue&White's Avatar
BleedingBlue&White
Here was my experience with this issue so far. I have a 1993 F-150 302. I bought the delete pulley from Summit for about $50. Bracket and everything mounted perfect, however the pulley with the delete bracket is smaller than what was on my smog pump. So far the stock belt on it will fit, but it buries the tensioner and acts like it's a worn out belt. (I.E. squealing when you hit the gas, at startup sometimes, and when the AC or Defrost is on). The factory belt is 99" and some change but I'm going to try a 97" belt tomorrow.
I also cut the exhaust just after the resonator and am running straight pipe up to the tailpipe for now. Truck sure sounds good, now if I can just find the right size belt...
Old Jun 30, 2012 | 09:56 PM
  #52
Edgethis's Avatar
Edgethis
Tensioner might be on its way out.
Old Jun 30, 2012 | 11:42 PM
  #53
BleedingBlue&White
Brand new tensioner too. Also I plugged the top ports of the solenoids with some 1/4" vacuum plugs.
Old Jul 1, 2012 | 12:14 PM
  #54
Bankrupter's Avatar
Bankrupter
GO to the auto parts store and pick up the a/c delete idler. they should have it in stock and it will replace that smaller mustang idler making the system work with the stock belt. ill go out in the garage and see if I kept the idler off that set up in the a/c box and grab the part # for you.. I had to do this also... thought I posted it.
Edit : Dayco 89013 (Knew I kept this clutter around for more then me...) I also feel like a dick because all the asking for update s I did in this thread, I never did myself. So here it is lol I got that same bracket you did, idler was to small, and there is my fix.. lol GL... now wheres my reps lol
Old Jul 1, 2012 | 02:14 PM
  #55
BleedingBlue&White
Well I read your post too late, but the good news is that i found a belt that works at my local Oreilly's. It is the Micro V belt number K060970. Now I'm just waiting on my exhaust to get here, put it on and be good to go!!!
Old Jul 1, 2012 | 05:51 PM
  #56
Bankrupter's Avatar
Bankrupter
KO- Gates belt?
Old Jul 1, 2012 | 06:33 PM
  #57
BleedingBlue&White
KO- Gates belt?
Didn't see that name on the packaging, but probably still a Gates subcompany. Taped a part of the packaging with the part number to the fan shroud so I won't have to do this again.
Old Jul 1, 2012 | 06:53 PM
  #58
Bankrupter's Avatar
Bankrupter
EHh if it is gates it will outlast the truck anyways. got an exhaust thread going?
Old Jul 2, 2012 | 12:28 AM
  #59
BleedingBlue&White
No, I figure I've done so much exhaust work like this I figure I could do it blindfolded. Funny, not many people that I've bumped into know that the 302 sounds pretty darn good if you cut the exhaust behind the resonator and in front of the converter and just run pipe the rest of the way. Don't even need to spend money on a performance muffler.
Old Jul 8, 2012 | 08:57 AM
  #60
khakushia's Avatar
khakushia
need pics
Can anyone post some pictures of what it looks like without all the hoses and smog pump looks like. I am about ready to do this and i want to see what it looks like without all the extra baggage
