SMOG PUMP
Old Mar 12, 2011 | 08:54 PM
  #31
mr_malina's Avatar
mr_malina
Length for a 91 4.9 no A/C?
Old Mar 13, 2011 | 12:05 PM
  #32
White Max's Avatar
White Max
You'll probably need to measure that one yourself.
-Rod
Old Mar 19, 2011 | 07:05 PM
  #33
jborushko's Avatar
jborushko
i wound up needing 97" for my 351w with a/c idler pully
Old Apr 1, 2011 | 05:48 PM
  #34
blinkerfluid's Avatar
blinkerfluid
I have no smog pump... Just an idler pulley... Appears to be factory...
Also have no cross over tubes on head nor the manifold...
Also have no air running to the cats... Appears all to be factory set up in my 96 with a 351
Old Apr 1, 2011 | 06:19 PM
  #35
rla2005's Avatar
rla2005
Yes it is factory assuming your truck is a Bronco or F150 with OBD-II
Old Jan 21, 2012 | 06:09 PM
  #36
Bankrupter's Avatar
Bankrupter
OK NOW IM LOST AND YELLING DUE TO CAPS LOCK... .
One problem solved and moving on ... I have been searching this topic and till this thread all others said this could not be done on my 5.8 with the low mount tensioner. So can i do this or not? I hate the search feature and different info on different threads!
My air pump pluming was deleted years ago but was in place as a idler till today when it locked up plowing and cost me 2 hours at 65 an hour.... I dont care to gut it if this is a working solution. Need a new belt after todays lock up anyways...
EDIT/UPDATE
Parts guys are truly worthless around here. Any one have a part number for that 96.08" belt. I could almost get it from the pics here but just cant see enough of it.
Old Jan 21, 2012 | 09:54 PM
  #37
Bankrupter's Avatar
Bankrupter
Originally Posted by Bankrupter
EDIT/UPDATE
Gates K060960
This is a 96 inch I figured .08 of an inch is not that big a deal.. We will see
Staff note: Edit the junk tags ! 1988, 460ci, 93, 94, 96, f150, f250, f350, ford, home, motor, problems- waste of search terms add smog pump delete truck and trucks can go too.. some people dont get tags.
Old Jan 23, 2012 | 03:59 PM
  #38
Bankrupter's Avatar
Bankrupter
Gates K060960
Does not fit.... fail and no ride to parts store caz I pulled the smog pump to start. I knew to pull the pulley and test fit it first too lol... Im thinking that .08 is a typo of .80 97 looks like it will work and a later post of this thread said 97 also..
Old Jan 23, 2012 | 06:18 PM
  #39
Scndsin's Avatar
Scndsin
Bankrupter:
Found the old belt card with original Motorcraft belt stuck in it. Haven't been able to verify it with other FTE'r who cross-checked my last #, but here it is. DAYCO polyrib, primary #, 5060960, secondary #, 6PK2440
Old Jan 28, 2012 | 12:12 PM
  #40
Bankrupter's Avatar
Bankrupter
Originally Posted by Scndsin
Bankrupter:
awesome update bud! After buying 4 more belts I found only one gates belt I could get to fit w/o a crow bar wrecking the belt off the break. Its 70 1/8 th long but I have not updated this because it squeals at start up/big puddles. I cant find a 70" 69 and 7/8 ths was too short . About to pull the trigger on an smog delete idler I think. I cant have this slip when the boss calls for amperage plowing...
Old Jan 28, 2012 | 12:30 PM
  #41
Edgethis's Avatar
Edgethis
I have read all these threads too and decided to bite the bullet and get the delete bracket. It should be in today or tomorrow, ill let you know how it goes.
Old Jan 29, 2012 | 08:37 PM
  #42
76250_4x4's Avatar
76250_4x4
when i swapped in my 351 i tried rerouting the belt on my 94 the the low mount tensioner. after 5 trips to napa i put the smog pump back on and ran the stock belt. i tried evrything i could think of, i tried the same routing as the diagram posted by jborushko but it was not tight enough for me. i will be ordering the bypass pulley in the near future
  #43
Bankrupter's Avatar
Bankrupter
What MFGR did you go with price and site/store? I was looking at the two that Summit has. One says its up to 93 5.0 mustang.Thinking that will work on my 95 5.8. The one that lists up to 95 is just bling and over priced to me. Plastic and cast alloy is up to the task of an Idler for me...
Old Jan 29, 2012 | 08:48 PM
  #44
Edgethis's Avatar
Edgethis
I ordered the Ford Racing one locally at Advance auto. I got it for about $95 it should be here tomorrow.
Old Jan 29, 2012 | 09:01 PM
  #45
Bankrupter's Avatar
Bankrupter
LOL I didnt even knew they made it. Only Ford Racing idler I knew off was the A/C delete - P/S relocate bracket or Idler depending on year. Look forward to your update
