Aerostar Ford Aerostar
egr
Old Feb 23, 2010 | 07:12 PM
Donnie Reeves's Avatar
Donnie Reeves
egr
I have 95 aerostar with 4.0. tried using vaccum lines to find egr valve.......no luck. tried finding egr riser tube.....cant find that either. i think egr should be on drivers side but not positive. also, i thought someone may have taken egr off but i cant even find any evidence of anything like a riser off exhaust manifolds. can anyone tell me where the little houdini is supposed to be in detail? It failed emissions due to high nox. egr or cat conv. probable causes (so i'm told). has 1.5 year old cats.
Old Feb 23, 2010 | 08:31 PM
KhanTyranitar's Avatar
KhanTyranitar
Not all models have them. My '94 4.0L does not have an EGR, but my brothers '97 4.0L does. It should be right on the drivers side exhaust manifold. If you don't see it there, then you don't have one.
If you put junk cats on, then it is reasonable to expect them to fail. I would suspect that is part of the story. But the other part of the story is that the original converter never should have failed. If it did then the car has a problem. That problem will eventually destroy every replacement converter you install. I know this is not hypothetical either, I deal in lots of converters. My Aerostar has over 220,000 miles, still has the original converters, and is very close to zeros on HC, CO, and NOX.
You should perform a complete tune up including plugs and wires using only the parts recommended in the sticky on the top of this forum. You can run Seafoam or Berryman's B12 through a vacuum line to clean the intake and combustion chambers. Replace all cracked or split vacuum lines. Clean the MAF sensor and replace all filters. Try the test again and if it fails after all that, you will need to replace the converters.
Old Feb 23, 2010 | 09:01 PM
Aeroman59's Avatar
Aeroman59
Post Probably not on your van.
Pre 1996 EGR was less common.
If you have EGR it will be plain to see, the components are not small, you would not miss them! Cant say about the 4L but on it's baby brother, the EGR tube comes off the Ex manifold right next to plug #6 (driver side rear plug). It basically rises vertically & connects onto the intake manifold via the EGR valve behind the IAC & TPS. There is also an DPFE unit in front of the EGR valve, which is vacuum controlled. Evidently it works quite well since I've never heard the engine pinging or knocking etc. Also NOX emissions are low. Problem is that the EGR tube is obselete, so if it rusts out or breaks....... big bucks!
Aeroman.
Old Feb 24, 2010 | 12:02 AM
99f350sd's Avatar
99f350sd
As said above my 94 didn't have one and the 95's don't either.. The only 95 ford to have one was the ranger..4.0. As far as I know..Ford did a big campaign in 96 fitting egr's and dpfe sensors to most of the vehicles they sold.
Old Feb 24, 2010 | 02:14 PM
copper_90680's Avatar
copper_90680
My '95 4.0L does not have an EGR.
Old Feb 24, 2010 | 03:00 PM
96_4wdr's Avatar
96_4wdr
high NOX on a non EGR engine is usually from a lean air/fuel mixture, too much oxygen. look for a vacuum leak, lots of tubing on the Aero 4L. vacuum christmas tree on rear of driver side valve cover, vapor canister system, intake manifold loose bolts, IAC stuck open partially, power brake vac. diaphram, etc.
EGR not until late 95 OBDII Aeros
Old Feb 28, 2010 | 09:52 AM
Donnie Reeves
thanks for all of you responding and ALL say my vanhas no egr. glad i'm not losing my mind. again thanks for the help. passed test after changing pcv and junk cats that prev. owner put on. all numbers are real good now!!!!!!!
olfordsnstone
Jun 20, 2013 07:19 AM
Feenba
Aug 13, 2012 08:11 AM
silver777
Dec 25, 2011 06:56 PM
moparman19
Jun 30, 2011 12:07 AM
mdacton
Dec 6, 2010 06:16 AM
