Leveling Kits
Old Mar 1, 2010 | 07:29 PM
jefff's Avatar
jefff
I finally got the pictures up. They don't show a lot because I have the bigger tires on. The stock size winter size do look too small for the truck when they are on.
Old Mar 10, 2010 | 02:24 PM
Scratcha's Avatar
Scratcha
Originally Posted by jefff
I have a 2.5" autospring kit in the front and a add a leaf in the back. This helps maintain the stock cargo cap. If you just lift the front you cannot take the same load you could before. With this kit and I easily clear 33x12.5x17 BFG tires on 9.5x17 Procomp 1079 rims. I am sure it would clear 35" tires but I bought the tires before I installed the lift.
I will put some pictures in my profile.
Hey Jeff,
What do you think of the "ride" in the front? The reason I asked is; I was reading some posts on a F150 forum, a few guys were putting the Autospring down, because they claim the "ride" was alot different once the Autospring kit was installed. They were claiming that the Protech leveling kit was better.
I don't see how; I mean Autospring is the first leveling kit I've seen for sale with a proper offset designed into it.
I'm still leaning towards the Autospring 2.5 or 3.
Let us know how the "ride" is; if it's any different than the stock "ride".
Old Mar 10, 2010 | 04:45 PM
1bad67sbf's Avatar
1bad67sbf
if your looking for good priced leveling kits check out www.hellbentsteel.com
Old Mar 10, 2010 | 08:16 PM
jefff's Avatar
jefff
Hi,
I didn't find it change the ride very much at all. I also went with 8 ply tires the same day I installed the lift. That would have also made the ride stiffer. Before this truck I had a F-250 with an extra leaf in all corners so this truck rides like a dream compared to it.
Old Mar 10, 2010 | 08:23 PM
jefff's Avatar
jefff
Is protech one of the rubber or plastic levelling kits? I drive a lot of gravel roads and logging roads so I wanted steel parts in the levelling kit
Old Mar 11, 2010 | 01:03 PM
Scratcha's Avatar
Scratcha
I haven't seen the Protech leveling kits yet. Thanks for the reply on your Autosprings. I was looking at Rancho and Bilstein, they have the height adjustable shocks; but it sounds like they are increasing the pre-load of the spring, that has to be alot stiffer than the stock.
Old Mar 11, 2010 | 01:49 PM
PinMd's Avatar
PinMd
I has the 1.5 AS kit installed today and thought it did a pretty good job of leveling it up.
Old Mar 11, 2010 | 02:05 PM
GHeTTo JOe's Avatar
GHeTTo JOe
that 1.5 AS kit is that just front end or anything lift in the rear?
Old Mar 11, 2010 | 02:23 PM
PinMd's Avatar
PinMd
Just the front, the rear is stock.
shark1979
6.7L Power Stroke Diesel
23
Dec 8, 2013 09:46 PM
04Fx4F150
2004 - 2008 F150
Mar 21, 2012 03:38 PM
superdooty89
Jan 28, 2012 02:21 PM
driller tom
2004 - 2008 F150
Apr 23, 2010 05:02 PM
04bluescab
2004 - 2008 F150
13
Jul 2, 2004 07:11 AM
