propane powered ford
Old Feb 28, 2010 | 09:06 AM
  #61
83mike's Avatar
83mike
Yeah i remember that. I can't remember who made the setup they used though.
Old Feb 28, 2010 | 10:26 AM
  #62
blueeyedfordguy's Avatar
blueeyedfordguy
yeah, jasper also sells a propane set up for carbed engines. Not sure who made the dual fuel one used on extreme 4x4, but that is a good show. http://www.jasperengines.com/rock-crawler.php
Jasper has 4.9L, 5.0, and 5.8 propane powered engines for around 2000$. I bet for under 3000$ you could have a bullet proof, great working system. But, I still think dual fuel would be more handy really. The gov't is giving a 0.50$ tax credit for every mile traveled on alternative fuel! Very nice. Well, at least that is what I read out of it.. http://www.npga.org/i4a/pages/index.cfm?pageid=1186
Faq on jasper alt. fuel engines: http://www.jasperengines.com/alterna...ngines-faq.php
Thanks for all the info and input guys, really helps
Old Feb 28, 2010 | 11:21 AM
  #63
jem44357's Avatar
jem44357
Cool thread. I'm in. I will be watching. I have read that turbos/propane work well together. Anyone know the cost of running a block heater? It would be a factor in the $ game if it matters. I like the "being different" and the "cool" factors which will always = MO $$$$. Especially if you are trying to hotrod an inline six. This thread may just help me realize one more of my dreams.
BTW if convenience/cost are a concern I think I have heard you could install a pig and purchase when cheap and fill 'er up when ever you need it.
Take Care
Jim
Old Mar 1, 2010 | 09:59 PM
  #64
blueeyedfordguy
Take Care
Jim
Yes, I believe you can even buy block heaters through lmc truck. Great company. There are quite a few companies you can buy block heaters through. Glad this thread has promoted so much interest
Old Mar 1, 2010 | 10:22 PM
  #65
86bigred's Avatar
86bigred
block heater will run you about $20.oo.you just remove a frost plug and insert it in the plugs place.
Old Mar 2, 2010 | 02:22 AM
  #66
ozstang65's Avatar
ozstang65
Originally Posted by greyghost85
.. folks dont want to concern themselves with the added inconvenience.
What's the inconvenience for you guys? Availability?
I'm getting a Sprint Gas system for my truck soon (351C) and it will be dual fuel with 2x 90L gas tanks. It will cost about $4k to install but there's a $1750 government rebate in place at the moment. With gas at $0.65/l and 95 Octane Petrol at about $1.20 the cost of it will not take long to recoup. It will use more gas then petrol, some say up to 30%, either way it ends up cheaper and is much cleaner for the engine.
If you have hardened seats to run on unleaded then you can run on gas as well. Most systems come with an oiling system that keeps the valves lubricated anyway. If you want to build an engine dedicated to gas (increased comp ratio) then you can regain some of the power loss of a dual fuel engine.
Old Mar 2, 2010 | 10:37 AM
  #67
86bigred's Avatar
86bigred
i'v had unleaded factory valve seats go bad,that's why I sujuested replacing them.a friend of mine rebuilds engines for a living says the same thing.
Old Mar 2, 2010 | 02:53 PM
  #68
blueeyedfordguy
How does the government rebate work? I would bet your vehicle would have to have a cadilidic converter, and pass emissions test + an inspection? Things like that?? Im sure it would pay you back your money in the long run. I read on jasper it was .50$ per mile for the rebate. Thats pretty cool. Im not sure though. Yeah, you can get a universal block heater as tractor supply for 40$ that just replaces the freeze plug. I've also seen them on the top radiator hose, but I would perfer it on the freeze plug location. Not bad at all.
Old Mar 2, 2010 | 07:16 PM
  #69
greyghost85's Avatar
greyghost85
the heaters we used in Alaska, spliced easily into the HEATER hose....thats the route I would recommend
Old Mar 2, 2010 | 07:39 PM
  #70
83mike's Avatar
83mike
Like this? http://www.jcwhitney.com/tank-type-e...41&zmap=540691
Old Mar 2, 2010 | 07:51 PM
  #71
86bigred's Avatar
86bigred
I have seen those keep the coolant at 180*when plugged in.no need to warm the engine up.LOL
Old Mar 2, 2010 | 07:58 PM
  #72
83mike's Avatar
83mike
The one i posted goes to the heater hose i believe.
Old Mar 2, 2010 | 07:59 PM
  #73
greyghost85
yessir, mike....looks very similar
Old Mar 2, 2010 | 08:00 PM
  #74
83mike's Avatar
83mike
Cool. I may actually pick one up for next winter. I hate starting my truck in the cold it's a PITA till it warms up (oh the joys of carb.). I was debating between coolant heater or oil heater. or even both (but that seems like a waste of money and electric)
Old Mar 2, 2010 | 09:55 PM
  #75
blueeyedfordguy
maybe you could put in a new thermostat? Preheaters are nice. I love them for any diesel. But, they are an energy hog They draw a good amount of electricity. But to me its more then worth it to unplug a vehicle, get in, hit the key, and instantly have heat, and engine power. Saves on wear too.
My 302, I had to put a new thermostat, all new coolant hoses, water pump, and now even when its 10 degs or colder it doesnt take long to push out heat at all.
