Dome Light Override Switch - OOPS
Old Feb 25, 2010 | 06:50 AM
DSMMH's Avatar
DSMMH
Originally Posted by DznyRulz
I finally got the plug out, they weren't kidding about it holding well, and got the panel off. I found the wires. Both wires are in one plug. I believe its pin 4 that has the wire for the running boards and pin 13 has the wire for the interior lights. I cut the wire to pin 4 first and naturally, with my luck, the interior lights continued to burn bright so I cut the other wire and darkness came. I was only hoping to cut one wire but oh well. I butt connected the wires but then ran out of time. I'm trying to get this done with what little daylight I have left when I return home and in between rain and snow. We're expecting a few inches of snow tonight and tomorrow so hopefully I can finish up this weekend. At least the hard part is done, running the new wires and installing the switch is the easy part. I'll snap a few pics later.
Many thanks guys.
Chris
I had the same problem. Dome lights on all the time. Went into the instrument cluster wire harness and put in a switch until I could fix it.
Changed the "delay accessory" relay (#306) and that fixed my problem. Also, check fuse # 42 (delayed accessory).
An easy way to check, if the relay is the problem, is to swap relays #306 and #305. Shut the door and lights should go out after timer does it's thing (about 15 to 20 seconds).
You can fix the relay. Pop the top off and clean the black residue off the contacts. I removed the spring and the pivot arm so I could clean the contacts good and check for pitting. If the contacts are pitted, recommend getting a new relay.
DSMMH
Old Feb 25, 2010 | 08:31 PM
DznyRulz's Avatar
DznyRulz
DSMMH,
I think you misread what I was trying to accomplish. I don't have a problem with the delayed accessory feature, that works quite well. When we're camping, actually setting up or breaking camp, I'm in and out of the truck often. That, and keeping the rear door open for extended periods, means the interior lights can be on for quite some time. With an override switch I can turn them off when desired and turn them on when needed. Thanks for your suggestion though.
Chris
Old Feb 25, 2010 | 08:46 PM
DznyRulz's Avatar
DznyRulz
Well, it looks like my selective color blindness was acting up again yesterday. When looking at the wiring going into the plug I could've sworn that there were two BK/LB wires. Looking at it again today when the sun was shining a bit brighter, and with fresh batteries in my flashlight, I see that one wire, the first one I cut, was actually brown with the light blue stripe. In fact it looks like the same wire I mistakenly cut at the CJB. Since there wasn't much room for forgiveness I spliced it with a short length of 16ga. wire. If you look close at the top connections you can see the one on the left is black and the one on the right is brown.
For future reference, the BK/LB wire runs into the plug on the left. Naturally the one that's harder to get out.
I connected the wiring to the BK/LB wire for the switch. I tried the switch and it works! Finally! Now all I have to do is run the wires under the dash and install the switch. I still don't know what the brown/light blue stripe wire is for but now I have two places to look if something stops working. This will be a welcome mod. I just wish I had a garage to work in instead of in my parking space out front.
Thanks to everyone for the help.
Chris
Old Feb 26, 2010 | 08:07 AM
DSMMH's Avatar
DSMMH
DSMMH,
Chris
Yeah, I did. My bad!
My interior lights came on and would not go out. Real dangerous driving at night. Had to pull the dome light fuse and in doing so, I lost my instrument panel and radio but I got home. Could not figure out right away so I went into the instrument cluster and found the wire and installed a circuit breaker to kill the lights. My fix was what I wrote in the previous response.
DSMMH
Old Mar 13, 2010 | 09:47 AM
njneer1's Avatar
njneer1
Does anyone have the link to Monsta's instructions ?? Searched and couldn 't find it.....want to do this to my 2000 and need the wire color and location
Old Apr 2, 2010 | 11:49 AM
bigrigmike's Avatar
bigrigmike
I just did this, this morning and it took about 20mins if that. but i ran my toggle switch in to the glove box. NOW I HAVE COMPLETE CONTROL OVER MY DOME AND RUNNING BOARD LIGHT'S (in a evil laugh) HAHAHAHA!!!!!!
Old Apr 2, 2010 | 02:16 PM
wallz's Avatar
wallz
I know this is from a few days ago, but I thought that I would find and post the link. Hopefully it is still usefull, and I think that if you are like a lot of other guys you still have to get it done, so this will help.
Again this is for the 2000 X's, as the 02 and up have the wires in the passenger kick panel, under the fuel cut off switch.
https://www.ford-trucks.com/forums/2...5-xlt-dsl.html
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Apr 10, 2010 | 08:12 AM
njneer1's Avatar
njneer1
Thanks Wallz !!!!
Old Jul 14, 2010 | 08:53 AM
mark996's Avatar
mark996
Wanted to post another successful override here. A few no-brainer tips...don't use duct tape, and use the female spade connectors on the switch if you can. I just put the switch in the glove box, drilled a small hole and screwed it down, it's out of the way, and easily accessible. Thanks guys.
Old Nov 23, 2010 | 10:09 AM
SCourtney's Avatar
SCourtney
I did this mod last night in my 98 Expy directly behind the fuse panel. I have the correct BK/LB wires run to my switch and it kills the interior and running board lights.
My problem is that the associated relay is activating/clicking on/off and will not stop. Could I have a bad relay??
Old Nov 25, 2010 | 09:12 PM
9mpg's Avatar
9mpg
I'm thinking I'll put my switch between the dimmer and headlight switch... sort of like my 2001 Chevy Express 3500 work van. (I have never been a Chevy Guy, but I am impressed that it is at 313k and still going strong...35k of that in the last 6 months)
Old Nov 25, 2010 | 09:25 PM
mark996's Avatar
mark996
Funny this thread came back, today I was thinking about placing my switch somewhere more accessible from the driver side, like a toggle on the bottom area of the center console, or some other place on the dash. Who knows.
Old Nov 25, 2010 | 09:53 PM
  #28
Rickx's Avatar
Rickx
This is how I delt with it.
ByPass Door Ajar
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message -->This will accomplish what you want. This is an '03.
I've had my X since it was new. I got it 2002. I had a 2000 model I bought new before that. I had a 1997 F150 with the same problem. I've been dealing with this a long time. I finally decided to make a bypass and give myself options for when it happens.
I removed the instrument panel and spliced a wire into the Black / Light blue wire. This wire is located on the connector furthest toward the passenger side. It is the only wire of this color anywhere on the instrument panel. I ran that wire through a toggle switch that I mounted in the dash just to the right of the headlight switch.
Now I control the interior and running board lights with the flip of a switch.
If a door jamb switch malfunctions, I just turn off the lights manually.
If I want to leave the doors open when I'm camping or for any reason, I just flip the switch.
If the door ajar switches are working correctly I just leave the switch in the on position.
If they are malfunctioning, I just turn on the switch as I am entering the X and then turn it off when I'm ready to roll.
The reading lights and the cargo light in the back still operate normally regardless of this switch position.
This is the best thing I've done yet to the X.
<!-- / message -->
Old Dec 2, 2010 | 09:23 PM
  #29
shadetreetx's Avatar
shadetreetx
Just did this mod for a long trip with a 2.5yo & 6 week old. I have it hanging out of the garbage hook for the moment. Any idea what is next to the power plug above the cup holders on the dash? Can I install it there?
Thanks
02 X 4x4 7.3 Ultimate
Old Dec 5, 2010 | 09:16 PM
  #30
wpnaes's Avatar
wpnaes
I took a stab at the over ride switch today, getting bruised knuckles in that tiny space. I have a 2000 Ex and have shared 4 picture in my 'various' album. Can someone tell if I'd ID'd the right wire? Seems more blue than black. i guess i can just cut and see what happens...
Thx
