Can YOU do brakes?
Old Feb 20, 2010 | 11:52 PM
OrangeJuice's Avatar
OrangeJuice
Question Can YOU do brakes?
Hello,
Just wondering how many of you do your own brakes on your truck? I've been thinking I should learn to do it myself and save some $$$$. My truck has disk front and drum rear. For those of you who do them yourself, are they easier or more difficult than the newer cars?
Thanks
OJ
Old Feb 20, 2010 | 11:57 PM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
The new cars/trucks with 4 wheel disk are just stupid easy. Older stuff isn't really hard......it's just more time consuming and a lot more messy!! Also, it's not completely fool proof. You can assemble stuff incorrectly. It's almost impossible to screw up the brakes on a late-model.
Also, drum brakes suck.....and I'll leave it at that.
Old Feb 20, 2010 | 11:58 PM
brad302's Avatar
brad302
are you talkin about brake pads?
Old Feb 21, 2010 | 12:05 AM
montana_highboy's Avatar
montana_highboy
It's a lot easier than you're probably thinking, if you doubt your ability just tear down and work on one side of the truck at a time, leaving the other side intact to use as a reference if need be.
Old Feb 21, 2010 | 12:31 AM
Hickfied's Avatar
Hickfied
Disks are easssyyyy. I've never had to mess with drums. Just tear into it, you will figure it out. If not, that is what specialized forums like this one is for.
side note: At 16 years old, it took me an hour to find the oil filter on my Toyota 4-Runner. Now, thanks to specialized forums, at age 21 I have stripped a Mustang to the bare chassis and rebuilt it into a low 10 second drag car capable of 9's, and have completed a frame off resto on a 79 F150 4X4 and a 77 F100 2wd.
Old Feb 21, 2010 | 02:36 AM
WyoExplorer's Avatar
WyoExplorer
I ALWAYS do my own, that way I know there is only one person to blame if it's not done right, I myself have a very VERY hot temper, so if I were to go back, i'd surely be kicked out.
Old Feb 21, 2010 | 03:47 AM
460/5's Avatar
460/5
Zombie Survivalist
im the only one whos ever done my brakes. as a rule, you will change the rear pads every third time you change the front. disk brakes are so easy, i can dang near do em blindfolded on my trucks. just a note, there is a bolt you have to take out of the caliper on the front to get em off. the drums are a bit more involved, but arent too hard.
Old Feb 21, 2010 | 11:52 AM
Tees77f150's Avatar
Tees77f150
Thumbs up
If you have a digital camera, pull off a piece and lay it out in the order you took it off, and take a picture every time you take something off. Then when you put it back, the parts are in order, and you can look at the pictures.
And remember you got plenty of FTE brothers here to help you out!!
PS: The front disc is SO easy, even a cave man can do it!!
Old Feb 21, 2010 | 07:44 PM
460/5's Avatar
460/5
Zombie Survivalist
I RESENT THAT COMMENT!!!
Old Feb 21, 2010 | 09:43 PM
XzXPatrickXzX's Avatar
XzXPatrickXzX
Here is a diagram of drum brakes i found on here somewhere that i thought was really cool and helpful:
Old Feb 21, 2010 | 10:06 PM
bucks77ford's Avatar
bucks77ford
Get a Haynes Manual also. I've rarely done brakes before and I had no problem on my F250 4x4. Like stated before, do one side at once and take pics if need be.
Old Feb 21, 2010 | 10:12 PM
460/5's Avatar
460/5
Zombie Survivalist
i will note, ford drums are easier than chebby drums. the little adjustment lever in the chebbys tends to not want to stay where its supposed to when you put em back together...
Old Feb 21, 2010 | 11:26 PM
psychonoline's Avatar
psychonoline
I'm the only one who does brake work on my vehicles. I've had shops screw up far less critical things too many times to be comfortable otherwise. I think the newer stuff is easier to work on, up to a point. Once you start cracking open hydraulics or running brake lines, old stuff wins hands down.
-Josh
Old Feb 21, 2010 | 11:58 PM
John68's Avatar
John68
Doing your own work to save money is a loosing battle. By the time you buy all the tools to fix every aspect of your truck, you will have thousands of dollars wrapped up in tools. Don't skimp on tools, either. Buy good stuff, or it will come back to bite you later. Also, don't buy the prepackaged sets that give you 10 sockets, and 40 nut drivers. That's just a waste of money.
Old Feb 22, 2010 | 01:01 AM
Hickfied's Avatar
Hickfied
+1. When I started buying tools, I bought two of each: 3/8 and 1/2 SAE and metric short sockets 3/8 and 1/2 SAE and metric deepwells for eight sets of sockets from 5/16 to 1 1/8 and 8mm to 22mm. Along with two sets of combo wrenches in both metric and SAE.
