I read all these posts and try to make sense of all the abbreviations but I need your help. Does anyone have a list of abbreviations that you would share with me? The only one that I'm real sure of is EGG. I had one of them on my bacon sandwich this morning. Thanks in advance!
EGR = Exhaust Gas Recirculation (Bleeds exhaust gas into the intake to minimize NOx)
ICP = Injector control pressure. Monitors the Oil Pressure that actuates the injectors
MAP = Manifold Absolute Pressure. Measures the air pressure in the intake manifold
MAF = Mass Air Flow. Measures the Air flow through the Intake Air filter.
IPR = Injection Pressure Regulator. Monitors and controls Oil High Pressure
DTC = Diagnostic Trouble Codes. Use a scanner to find them and diagnose from there
VGT = Variable Geometry Turbo. What the 6.0L is equipped with. Basicly a solenoid (I think) alters the angle of the impeller blades to increase or decrease boost as needed.
There are more I am sure, but these are the ones I know. Hope they help
