Need Help with Abbreviations
Old May 25, 2016 | 11:38 AM
Texasdeereandhorse's Avatar
Texasdeereandhorse
There are several abbreviations used in the posts in these threads and I don't know what a lot of them stand for. Is there somewhere where they are all listed in a sticky or something? Example, CEL, PSD, OBS, ICP, HPO and alike. Thanks
Old May 25, 2016 | 12:05 PM
FI460's Avatar
FI460
https://www.ford-trucks.com/forums/1...finitions.html
Ask and you shall receive.
I actually don't see some of the PSD specific ones... There's another list somewhere I think.
Old May 25, 2016 | 12:11 PM
Texasdeereandhorse
Yes, I just looked and didn't see any myself. I hope you can find that list.
Old May 25, 2016 | 12:39 PM
farmert's Avatar
farmert
Here you go-- Thanks to Mike for posting this! https://www.ford-trucks.com/forums/1...nsor-info.html
Old May 25, 2016 | 01:05 PM
fordpride's Avatar
fordpride
CEL check engine light
PSD powerstroke diesel
OBS old body style
ICP injector control pressure
HPO high pressure oil
HPOP high pressure oil pump
IPR injector pressure regulator
FPR fuel pressure regulator
CPS camshaft position sensor
VSS vehicle speed sensor
EBPV exhaust back pressure valve
EBPS exhaust back pressure sensor
UVCH under valve cover harness
IDM injector driver module
PCM powertrain control module
TRS trans range sensor
corpuspits
Feb 1, 2009 03:54 PM
stroken
Aug 23, 2007 02:31 PM
dinikin
Jul 29, 2007 06:06 PM
ForemanES
Mar 29, 2006 05:42 AM
HeatStroked
Sep 8, 2004 07:52 PM
