393 stroker
Old Feb 19, 2010 | 09:56 PM
jonbass40's Avatar
jonbass40
393 stroker
Hi Everyone. Im considering building a budget 393 using either an eagle or scat crand and stock 351 rods 302 pistons. What would you guys suggest for heads? I was thinking either the windsor sr or jr iron heads but with the 58cc chamber im having a hard time finding an affordable budget minded 302 piston. Does anyone have any ideas and or experiences? Id really like some imput.
Thanks Guys
Old Feb 19, 2010 | 11:06 PM
82ford302's Avatar
82ford302
depending on your budget, afr 185 outlaws and a ross/weisco piston is in the list of stuff to get. if ross and weisco is too much look into probe or kb forged. dont skimp on heads if its a performance motor, will bite you in the azz later on.
Old Feb 20, 2010 | 06:03 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Summit sells a set of hypereutectic 302 flat tops for $99.
+6 on the AFR185 heads.
Old Feb 20, 2010 | 10:03 AM
Conanski's Avatar
Conanski
Get a set of 64cc RHS heads, they're vastly superior to any of the World heads.
Racing Head Service 35301-01 - RHS Pro Action Small Block Ford Cylinder Heads - Overview - SummitRacing.com
Old Feb 20, 2010 | 08:34 PM
jonbass40's Avatar
jonbass40
I guess i should say that im shooting for approximently 400hp to 425hp with my redline at 6k. I was under the impression that the world heads would be good enough to get those power levels. I would like to run 64cc chambers with the keith black hyppers with 22cc dish to keep the compression down to about 9.3 to one so I can run the cheap gas if neccessary. I would like to stay with iron heads to keep the costs down. What cam would you recomend for a moderate performance build? Would a 224/234@ .050 with .497/520 be to radical to have decent enough vacume for brakes? I should also mention that this will be going into a f150 backed by a zf with 3.55's It doesnt ever really do any towing just more for fun and crusing. Sorry about all the questions, I just want to have a solid idea of what to shoot for before I put down my hard earned cash.
Thanks
Old Feb 20, 2010 | 11:06 PM
Conanski's Avatar
Conanski
No the World heads will leave you well short of the mark, the RHS 180's are exactly what you want. Here is a dyno sim of one potential combo..
http://farm3.static.flickr.com/2716/...792f0c6b_o.jpg
Old Feb 21, 2010 | 10:22 AM
jonbass40's Avatar
jonbass40
looks like a pretty good combination. I looked into the RHS heads and for the slight increase in price they look like a much better performer. Summit even has a special on them for 489 assembled. Not a bad price at all.
Old Feb 22, 2010 | 10:39 AM
Kemicalburns's Avatar
Kemicalburns
will this be efi or carb?
Old Feb 22, 2010 | 01:05 PM
jonbass40's Avatar
jonbass40
Forgot to mention that, it will be carbed, probably a 750
Old Feb 26, 2010 | 09:00 PM
393STROKER's Avatar
393STROKER
I had some good results using the Eagle stroker kit w/Trick Flow(Pobe) pistons and Trick Flow 61cc heads(home ported) ,But I remember that we couldn`t use the rod bearings that came in the kit because they where rubbing on the radius`s of the crank journals.Check for rodbolt to cam clearance.YouTube - 393STROKERer's Channel
1966_F100
Sep 14, 2014 10:26 AM
FordMuddin'
Jul 5, 2012 09:49 PM
Gibby55
May 24, 2011 03:41 PM
wvroughneck
Jan 3, 2011 02:19 PM
quentrm250
18
Aug 12, 2003 08:05 AM
