393 w/ stock 302 pistons
How, pray tell, would it be a stroker with the stock crank?
Read through this thread and the links given:
https://www.ford-trucks.com/forums/1...-possible.html
Stroke is determined by the crankshaft, so if you use a stock 351 crankshaft with 302 pistons, you'll just end up with a 351 with 302 pistons. I have seen somewhere that the 302 pistons can be used with a stroker crankshaft (393?) but I haven't done a lot of research on the subject so I don't know for sure.
a cheapo 393 uses the 3.85" stroker crank with stock 351w rods and .030" over 302 pistons (1.6" pi height)
A real 393 uses longer aftermarket rods (6.2") and special pistons with a pin height around 1.45".
If youre thinking about building a 393, first of all it will be a 387 untill you bore it out. Second, youll get more out of the top end if you spend the same amount of time & money on it, as opposed to pulling your engine right apart to get 35 more cubes on an already choked engine.
Rockers, cam, intake, headers yadda yadda.
Don't forget that you will have to clearance it for the stroker just as much as you would if you did a real 408 kit which has much more stroke. So if you buy the right rods 6.2 and pistons anyway the only change is 4 inch stroke and a shorter piston pin height. Cost the same in kit form usually.
aldeangibbs!
04-24-2013 06:41 PM
FordMuddin'
07-05-2012 09:49 PM
moore89
09-20-2003 07:14 AM
scott9320
03-25-2003 10:25 PM
