Optima Battery
Old Feb 19, 2010 | 05:26 PM
bkuuz1's Avatar
bkuuz1
Optima Battery
Question,
I'll be needing batteries soon.
Live in CO.
Do you think the Optima battery is worth the 170.00. You guys who use them how long do the last? seems like I only get two maybe three years out of the Costco bats I've been putting in the truck.
Thanks Brice
Old Feb 19, 2010 | 06:07 PM
clux's Avatar
clux
Originally Posted by bkuuz1
Question,
Live in CO.
I don't think so.
Old Feb 19, 2010 | 06:56 PM
crazymut's Avatar
crazymut
Shop arround. Do you have a Costco near you? You can get the red top for around $140. I have had them for about three years with no issues at all.
Old Feb 19, 2010 | 07:03 PM
240spoke's Avatar
240spoke
I had one of those on my cj7...They are great....I dont know about the cca...What are they, what do 7.3's need?? MATT
Old Feb 19, 2010 | 07:22 PM
crazymut's Avatar
crazymut
IIRC they are 800 cca
Old Feb 19, 2010 | 07:24 PM
crazymut's Avatar
crazymut
Just checked they are 800 cca
Old Feb 19, 2010 | 07:41 PM
PSDLOVER's Avatar
PSDLOVER
They are great.
But has been said, shop around. Maybe online. I got a pair for about $130/ea when on sale at 4wheelparts. They have been a godsend for me. I went thru acouple brands before Optima and they went bad quickly and leaked acid out the top because I am always bouncing in 4x4.
Old Feb 23, 2010 | 06:55 PM
Jerry Edwards's Avatar
Jerry Edwards
Optima Battery
There great,I have one in my race car with a 540 that is 14 to 1
Old Feb 24, 2010 | 12:16 AM
BobbyDiesel71's Avatar
BobbyDiesel71
I would say there are great, but look to Walmart or Sears. Most batteries are made by Johnson Controls and per store offer a Free three to 5 year replacement warranty.
I have Sears Die Hards(gold series)
good luck!
make sure you buy the batteries that match or exceed CCA and CA for your diesel truck
Old Feb 24, 2010 | 12:38 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Since Optima has moved there operations our of the country, to Mexico IIRC, the Yellow tops in my truck will probably be my last. I will probably go with Odyssey next as they have higher CCA from what I have seen. Not cheap batteries, but they are quality.
Odyssey PC2150 series battery
Old Feb 24, 2010 | 01:06 AM
crazymut's Avatar
crazymut
What type of bat is Odyssey, gel, AGM, standard lead acid?
Old Feb 24, 2010 | 01:17 AM
ff1210's Avatar
ff1210
batt
deka 665mf is what i run never had any prob they have over 1000 ca and 800s cca 4+ years
Old Feb 24, 2010 | 01:59 AM
Riffraff Diesel
PREMIUM SPONSOR
Construction
• Pure virgin lead plates for maximum surface area, optimized recycling
• AGM (absorbed glass mat) design eliminates acid spills
• High conductivity, corrosion-resistant tin-plated brass terminals
• High integrity terminal seal
• Sealed design—gases recycled internally during operation or charging
• Safety relief valve per cell
• Robust intercell connections prevent vibration damage
Better warranty
Limited 3- and 4-year full replacement warranty – not pro rata.
Longer service life
With 3-10 years of service life, ODYSSEY
TM batteries save consumers
time, money, and aggravation.
Longer cycle life
70% longer cycle life compared to conventional deep cycle batteries –
up to 400 cycles at 80% depth of discharge – high stable voltage for
longer periods of time.
Longer shelf life
Can be stored on open circuit (nothing connected to the terminals) without the need for recharging up to 2 years or down to 12.00V, whichever occurs first.
Faster recharge
The highest recharge efficiency of any sealed lead battery on the market – capable of 100% recharge in 4 - 6 hours.
Mounting flexibility
Non-spillable design – can be mounted on any side in any position except inverted.
Vibration resistance
Design protects against high impact shock and mechanical vibration –
a common cause of premature battery failure.
Extreme temperature tolerant
Operating temperatures from -40°C (-40°F) to 80°C (176ºF).
Totally maintenance free
No need to add water, ever! Drycell design with resealable venting system.
Improved safety
US Department of Transportation classified as a ‘non-spillable’ battery.
No acid spills, no escaping gases.
Old Feb 24, 2010 | 07:58 AM
mechelement's Avatar
mechelement
Optima batteries are best in the garbage at your house or on the shelf at any retailer.
Old Jul 30, 2010 | 01:08 AM
Nick 99's Avatar
Nick 99
Your truck came with 1000cca batteries, and require the same as replacement. Optimas only have 800CCA, so you are short 400cca when installed in our trucks.
