Optima Battery
Old Jul 30, 2010 | 01:18 AM
twags6's Avatar
twags6
Originally Posted by Nick 99
Your truck came with 1000cca batteries, and require the same as replacement. Optimas only have 800CCA, so you are short 400cca when installed in our trucks.
Not so sure about that. My 01 had originals when I changed them and they were 750 cca's. I ended up going with two Mototrcraft 850 cca's. Starts like a champ now.
Old Jul 30, 2010 | 11:52 AM
itsjustdan26's Avatar
itsjustdan26
Optima's have a high return rate. Clay is correct. They are made in Mexico and I will not buy one. Even though I get them at cost. They are junk. Once they left country the quailty went down by 100%. They closed down the last plant in the states ( Aurora Colorado ) about 1.5 to 2 years ago. Go with Motorcraft or Cosco brands. Cosco was rated number 1 in the 2009 Consumer Guide.
Old Jul 30, 2010 | 03:04 PM
hosoria's Avatar
hosoria
I bought a set of yellow tops and they were the best for about 1 1/2 and that was it. For the price i paid not worth it at all. I went to my local batterry place mom and pop place got some withh a two year replacement plan lot less and lot more CCA's out of them..Never plan to purchase optimas again....
Old Jul 30, 2010 | 04:21 PM
orng1's Avatar
orng1
I think the diesel engine might need to crank to hard for the battery. It has worked well for my explorer since I got it a few years ago now.
I think I have a spare set somewhere, I'd like to try them in my 7.3 for all of us that are wondering if they are any good for the big heavy engine.
Old Jul 30, 2010 | 04:27 PM
SpringerPop's Avatar
SpringerPop
Is Odyssey serious?!?! $350 for a single battery?!?
Aren't they the same as the DieHard Platinums?
And here I thought the Platinums were a bit pricey....
Whew!
Pop
Old Jul 30, 2010 | 04:29 PM
orng1's Avatar
orng1
Yeah they are serious, my cousin has 4 in his van. He has a serious audio set up. Head installer at a shop has to have something to show off.
Old Jul 30, 2010 | 04:54 PM
jirwin's Avatar
jirwin
odyssey battery that is called for for a 7.3 is the pc1750T $286.43 for one. 4 year free replacement. The lady did say average life expectancy is 8 to 10 years.
Old Jul 30, 2010 | 11:48 PM
itsjustdan26
In almost 6 years, I've hardly even seen a Odessy battery come into my store. And I see alot of batteries come in. I will not spend that much for a battery though. I will buy costco or the ones at my work. Happy reading all!
Old Jul 30, 2010 | 11:53 PM
hiredgun18's Avatar
hiredgun18
I have a redtop in my mustang drag car,first one lasted over a yr. and just died one day,and i kept it on a charger. Second one is still going so far for 4 months. When this one goes,no mo optima's for this guy.
Old Jul 31, 2010 | 12:54 AM
Jerry Edwards's Avatar
Jerry Edwards
My Red Top has bine in my 2002 TransAm chassis car for 5 years,my alternater doesn't charge till 2500rpm,and i put it on trickle charge the night before i go racing.I have had no problems with mine.I guess i have bine lucky!
Old Jul 31, 2010 | 02:24 PM
Fat Diesel's Avatar
Fat Diesel
I ran the stock batteries from the truck's birth in 10/98 until about 2003. I put Red Tops in and they worked fine in 2008 when I pulled them to put in the Falcon and Dune Buggy. I put Yellow Tops in the truck then and they're still doing fine. One Red Top failed last year after 6 years but the other is still in my 64 falcon convertible (battery in trunk) and it spins the 289 right up.
Odyssey sounds good though. Is it made in the USA?
Old Jul 31, 2010 | 06:21 PM
mechelement's Avatar
mechelement
My Jeep's yellow top won't hold a charge anymore. I said screw it and bought a lead acid battery. I'm holding onto the yellow top to see if I can hit it with a 100amp charge to revive it. It seems like Optima batteries can't sit w/o dying.
Old Jul 31, 2010 | 11:55 PM
  #28
brian42's Avatar
brian42
Veteran: Navy
Originally Posted by Riffraff Performance
Since Optima has moved there operations our of the country, to Mexico IIRC, the Yellow tops in my truck will probably be my last. I will probably go with Odyssey next as they have higher CCA from what I have seen. Not cheap batteries, but they are quality.
Odyssey PC2150 series battery
I do a lot of off-roading so the sealed gel is the way I went. I had a Red Top in my F-150 for 5 years trouble-free and I've had two Red Tops in my 250 for 2 years now without any trouble.
Thanks for the heads up Clay, I might have to reconsider when it's time for my next pair too...
Old Aug 1, 2010 | 12:03 AM
  #29
brian42's Avatar
brian42
Veteran: Navy
When I bought my truck, I think I only had 850cca Motorcrafts in there (the original owner had all of the service done at a dealership with OEM parts).
IIRC our trucks need at least 1500cca to fire up (electrics, glowplugs, starter, etc.), which is why one bad battery can leave you hanging.
Old Aug 1, 2010 | 09:55 AM
  #30
SGnAZ's Avatar
SGnAZ
You have got to post up a photo of that car
