Sponsored by: Real Truck
Transmission Temperature
Old Feb 22, 2010 | 03:36 AM
  #31
twags6's Avatar
twags6
Originally Posted by Mark Kovalsky
You don't have to get your truck to a warmer temp if you don't want to. It's your truck.
As a transmission warms and cools it draws air inside due to expansion and contraction. This air contains moisture. Some of that moisture will condense (ever seen dew on the ground where you live? That's condensed moisture) and collect inside the trans. Water and untreated steel will cause rust. I've seen steel parts inside transmissions rust and pit from moisture that collected in the trans.
150°F will work better to drive off this moisture than 140°F. Getting it over 200°F once in a while works even better. But I'm sure you know better than I do. Continue with what you've been doing, it seems to work for you.
Mark, whats a good way to get the 4R100 in my truck to warm up more in the winter. Does the bypass valve on the side of the trans have something to do with that? Once the outside temp dips below freezing, it takes at least an hour+ of driving to get the needle to move up from 100 (sensor is in the test port on the drivers side).
On the flip side, in the summers I can easily see 180-190 on a hot summers day just driving around unloaded. Is that considered normal or on the high side? Thanks!
Old Feb 22, 2010 | 02:05 PM
  #32
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There isn't a good way to warm up the trans other than driving it. You might consider covering the trans cooler with a piece of cardboard. The bypass on the side of the trans doesn't affect the warm up at all.
180-190 is normal.
Old Feb 22, 2010 | 02:07 PM
  #33
Mark Kovalsky
Originally Posted by Pinky Demon
If you go back and read every post I had, never once did I post in a sarcastic or condescending tone.
That's not how I read it.
If you didn't mean it that way, I sincerely apologize. I felt mocked, and responded in kind.
Old Feb 22, 2010 | 02:09 PM
  #34
senix's Avatar
senix
180-190 is normal.
180-190 is normal. That is good to know. Mine right now is running a bit cooler, I am sure because of the cold out there. What is the max (red line temp)?
Old Feb 22, 2010 | 02:38 PM
  #35
twags6's Avatar
twags6
180-190 is normal.
Ok, I'll give that a try and thats good to know those temps are normal.
Not to hijack the thread, but what is the purpose of the bypass?
Old Feb 22, 2010 | 03:16 PM
  #36
Mark Kovalsky
220°F is the maximum continuous temperature. You can go to 250°F for no more than 1/2 hour.
The bypass is there to allow flow to the rear lube circuit if the cooler is plugged. If there is no flow to the rear the trans will burn up very quickly.
Old Feb 22, 2010 | 04:14 PM
  #37
senix's Avatar
senix
Good to know I will set my alarms at 220F then so I dont cook the thing.
gascan
6.7L Power Stroke Diesel
20
May 22, 2014 07:52 AM
Steelheader87
Apr 13, 2009 01:02 PM
trandan
Dec 11, 2006 10:27 AM
rcknrbn
2004 - 2008 F150
33
Dec 10, 2006 10:31 PM
Edmund
Feb 27, 2006 08:45 PM
