Carb question
Old Feb 18, 2010 | 07:03 PM
83mike's Avatar
83mike
Carb question
83 F150 4.9l. Carter carb.
does someone have a picture of the mixture adjustment screws? Or a diagram. And what is the best procedure to adjust mixture.
Sorry for the NEWB question.
Old Feb 18, 2010 | 08:44 PM
4x4 Bart's Avatar
4x4 Bart
Just one screw at the base on passenger side of carb. Use a Vacuum gauge to get the highest reading at idle will get you very close.
Old Feb 18, 2010 | 09:16 PM
Argo's Avatar
Argo
Hey, how's the weather up in Reading? I used to be from Delaware County, just south of Philly. Anyway, do you have PA emissions testing in your county? If so, adjust the carburetor to max vacuum, then turn in the mixture screw 1/8th to 1/4 of a turn or until the vacuum gauge drops 2" of mercury, whatever happens first. That will keep your idle hydrocarbons down, and make the engine run cleaner for emissions testing.
Old Feb 19, 2010 | 06:51 AM
83mike's Avatar
83mike
Haha. The weather was nice yesterday. It's been pretty crappy lately though.
I do have emissions but it's visual only. I don't have access to a vacuum gauge at the moment. is there another way to test it? or in other words how do i adjust it for vacuum and mixture? or is it one and the same
Old Feb 19, 2010 | 09:57 AM
AbandonedBronco's Avatar
AbandonedBronco
I'd definitely recommend getting yourself a vacuum gauge. There's almost no tool handier for tuning an engine. Vacuum is everything. They're not that expensive either.
As for a quick means, the screw you're looking for is on the base and is facing the front passenger side. Turn it in until the engine just starts to hesitate and stumble, and then back it out a quarter turn.
If you can completely close the mixture screw (never tighten it fully, or you'll damage it) you have a vacuum leak.
Old Feb 19, 2010 | 10:34 AM
83mike's Avatar
83mike
K Thanks guys.
fdude64
Apr 26, 2020 05:13 PM
JayzDaddy
May 13, 2015 06:56 PM
Pitcrw6
25
Dec 9, 2012 04:28 PM
vls
Jan 1, 2012 06:52 PM
boggerted
Nov 29, 2007 09:22 AM
