ok, where did they hide them?
Old Sep 14, 2009 | 05:08 PM
fdude64's Avatar
fdude64
i cant find the mixture screws on my motorcraft holley carb. the numbers on the air intake horn are as follows...E3TE-9510-PD
LIST 50004-1
2983
CAN ANYONE HELP ME TO ADJUST THE MIXTURE ON THIS CARB?
Old Sep 16, 2009 | 04:05 PM
LxMan1's Avatar
LxMan1
You must remove the carb and drill or knock out the plugs in the front of the base plate. Then you will probably need a carb adjusting too to adjust them.
It is a 4180 series Holley.
Old Sep 16, 2009 | 05:44 PM
beetle's Avatar
beetle
There are 2 more screws on the secondary side too.
Old Sep 23, 2009 | 06:17 PM
crazyeddie's Avatar
crazyeddie
Cool someone else with a 4180
Like LxMan1 said, you have to drill out the plugs that cover-up the screws. Choose a drill that's a little smaller than the plug and drill through the plugs slowly so you don't damage the screws when the drill breaks through.
Once you have access to the screws you can adjust them with a small allen-wrench (don't know the size off the top of my head). The secondary screws are easier to adjust with a long ball-end allen-wrench since they face the firewall and are a pain in the butt to adjust when the carb's under the hood of a truck.
Old Apr 13, 2020 | 08:31 PM
RADC5335's Avatar
RADC5335
RADC5335
I found a Carb gasket kit with a 4150 flange base gasket and hardware to mount on my 460 intake maniford to mount this carburetor
OEM Carburetor 8-460 7.5L Manual Trans 83-85 FORD F250 PICKUP E3TE-9510-PD
that I found and purchased on ebay. I have not purchased the gasket kit yet until I found out if it will work. It's on cjponyparts. It's a kit for EFI but I'm not using the EFI gasket. I've sent in a message to their website asking this same question.
Thanks for your help. Building my 56 F-100
Old Apr 26, 2020 | 05:13 PM
FECruzer69's Avatar
FECruzer69
Sorry, deleted. Didn't realize how old this thread is.
bgn
Jan 24, 2019 06:32 PM
460tuff
Apr 30, 2013 07:05 PM
trkdrvr
Feb 23, 2005 09:29 AM
Stingray42
Jul 29, 2003 02:07 PM
Matt67
Mar 11, 2003 11:42 AM
