Is your truck overheating? Are you towing or snow plowing?
IMO the stock fan works well enough. Changing to electrics simply trades one for the other, with the advantages of the electrics offset by the increased load on the alternator and the complexity of the set up.
ive posted stuff about this before but never got the actual temp so thanks, and no it runs just fine, i just want the electric fan for the mpg increase that everyone has said they have gotten. ill get a temp gauge with actual numbers on it and a switch with a 20amp fuse to turn the fan off and on, so id say id turn it one if it ever got over 205?
