83 f150 300 timing adjustment
The first thing you do is check the timing. Then if it is off, then you can adjust. To check the timing, a common method is to use a timing light. This instrument fires a pulse of light every time the #1 spark plug fires, and this pulsed light is aimed at the timing marks on the engine to allow determination of whether of not the timing is correct.
The ways of adjusting timing depend upon what kind of ignition control system your truck uses. You have an '83 300-I6. Does it have a stock electronic ignition system?
The following users liked this post:
Ant-Knee
10-04-2016 07:17 PM
xphr8r
06-29-2016 06:48 PM
8086ford
02-10-2016 02:06 AM
edcwn
08-21-2010 12:07 PM
