strange starting problem
Old Jan 19, 2003 | 10:01 PM
szak's Avatar
szak
Unhappy strange starting problem
I have a 95 F-150 inline 6 with EFI. The problem I have seems to be getting worse, but it has taken a long time (over a year) to get to the stage it is at. When I go to start it, in about 30%-40% of the cases, the engine will brefily fire(about 1 second), then die. After that I have to step on the accelator and pump to get it started which takes about a total of 15 seconds using several cranks. If I wait after the first inital start to try again, then it seems to have less of a problem getting going. The cap, rotor, plugs and wires are new and OEM. I was thinking the Idler Air Control Valve, but There are several things it could be and I do not want to just replace and see what works.
Any help would be Great!!
Old Jan 20, 2003 | 07:37 AM
83Steve's Avatar
83Steve
Pull the codes:
http://www.broncodata.com/tech/codes.htm
Old Jan 20, 2003 | 02:15 PM
jellybellyjean's Avatar
jellybellyjean
our truck did the same thing about exactly (1992 Ford F-150) it turned out to be the upper intake gasket was bad. Fixed it and truck runs great. Good luck! Jean
Old Jan 20, 2003 | 03:18 PM
szak's Avatar
szak
I pulled the codes...nothing for the KOEO test(111), and the memory codes were incedental. The KOER test only gave me a 225 which is... Knock Sensor not detected during Dynamic Response Test KOER. That could have been because I did not "goose" it enough during the "goose" test.
Old Jan 20, 2003 | 05:12 PM
83Steve's Avatar
83Steve
No, that would have set code 167. The next thing I'd do is get a Haynes and a multimeter and test each sensor individually, starting with the IAC & TPS.
bambam0718
Aug 16, 2016 05:41 PM
Wolfracing
25
Nov 8, 2015 01:08 PM
norcoast
Dec 17, 2011 11:58 PM
StevensPoint
Mar 5, 2011 09:21 AM
Dmarkjohn
1983 - 2012 Ranger & B-Series
May 15, 2009 10:31 PM
