Scary Steering Glitch
Old Feb 16, 2010 | 02:52 PM
blockmanjohn's Avatar
blockmanjohn
After about a 50 mile drive on the interstate today, I go to turn off the exit ramp and the steering wheel wouldn't turn. After a little panic and a little more force it broke free and everything was fine. Up until then I had been changing lanes with no problems, but the exit required a greater turn of the wheel. Here's the really strange part. It happened one other time about 6 weeks ago. It was exactly the same trip on the interstate, and the same exit. The wheel did the same thing. Both times I had my snow plow on and it was snowing lightly. I find it hard to believe that this is just coincidence. Any body have any ideas before I take it to the dealer? By the way, I changed the power steering fluid about 8 months ago, and the level is still fine. Thanks, John
Old Feb 16, 2010 | 03:21 PM
utjer's Avatar
utjer
Any way the plow was slightly catching? I was thinking this since it happened in the same spot. Freaky coincidence.
Old Feb 16, 2010 | 03:30 PM
blockmanjohn
You know, I thought of that, but I always travel with the plow full up and very little angle on it. I also thought it might be snow build up in the wheel wells, but that wasn't the case. I'm afraid when I take it to the dealer they won't be able to duplicate it. I have an extended warranty that covers the suspension so I'll probably just spend the hundred bucks to see if they can figure it out.
Old Feb 16, 2010 | 04:56 PM
utjer's Avatar
utjer
Another thought, maybe it was snow/ice build up on the steering linkage. I doubt this could happen but you never know.
Old Feb 17, 2010 | 07:57 AM
GUNNERDOG's Avatar
GUNNERDOG
Just an FYI, the power steering uses mercon ATF fluid, NOT power steering fluid.....
Make sure you put the right stuff in there.
lilsuperdup
Nov 9, 2016 05:05 PM
spuds86
Sep 5, 2013 06:34 AM
Danny0295
2004 - 2008 F150
Jun 6, 2009 08:39 PM
Smokin'
19
Feb 18, 2008 06:47 PM
WVF150VIANC
1997 - 2003 F150
Jun 29, 2004 03:22 PM
