1985 Ford F-150 problems
Old Dec 19, 2004 | 01:23 AM
lilsuperdup's Avatar
lilsuperdup
A few days back I was driving on the interstate and after about 1.25 hours of driving I noticed my truck start to jump a little, kind of like it was about to run out of gas. When I exited about 10 minutes later I came to a stop at a light and the engine died. It did not run out of get because I had just filled it before I left. I tried to start it and it could not turn over. After a few minutes I managed to get it started but as soon as I put it into drive it died. So now I'm trying to figure out what the problem is. After it sits for a while it usually starts right up. It idles just fine but as soon as I shift to drive it struggles for a few feet and then sputters out. I've since replaced all the fuel pumps and all the distrubutor components and still the same thing occurs. If anyone has any suggestions I would greatly appreciate it. BTW, the engine is the original 1985 5.0L EFI.
Old Dec 19, 2004 | 03:09 AM
locknkey's Avatar
locknkey
What kind of codes from the computer are you getting? KOEO?
Old Dec 19, 2004 | 04:35 PM
jhm's Avatar
jhm
Do you by chance have dual fuel tanks?
I had a similar problem and it turned out that the fuel selector valve was stuck partway between the tanks, and the in-tank pump was bad in one tank.
When the reservoir bowl at the base of the fuel selector valve was emptied, the engine was out of gas.
When it sat long enough the reservoir would be refilled.
We figured out that the valve was stuck after we replaced all three of the fuel pumps and the fuel filter.
Old Dec 19, 2004 | 07:18 PM
lilsuperdup
I have the dual tanks. It seems to be putting out a good bit of flow/pressure at the end of the line where it plugs into the injector rail.
Old Jun 22, 2016 | 06:08 AM
vjsimone's Avatar
vjsimone
Did you ever find your problem??
Old Jun 22, 2016 | 08:18 AM
Gary Lewis's Avatar
Gary Lewis
His last post was 11 years ago.
Old Nov 9, 2016 | 05:05 PM
vjsimone's Avatar
vjsimone
I get lucky every now and then, but not this time,,,,,,,,
95_F2504x4_5.8
Feb 18, 2016 08:27 PM
Jjk27
Jul 9, 2015 03:38 PM
ineedit2001
1978 - 1996 Big Bronco
Mar 18, 2011 09:36 PM
tracyballard
Nov 5, 2010 11:48 AM
otter712
Jan 17, 2009 04:18 PM
