Offroad & 4x4
sterling questions
Old Feb 16, 2010 | 10:30 AM
dillinewton's Avatar
dillinewton
sterling questions
i just picked up a sterling and one of my friends said parts are limited and very expensive...im not sure if he has a clue what he is talkin about and i havent had time to look into it, so what do you all think?
Old Feb 16, 2010 | 10:36 AM
captain p4's Avatar
captain p4
uh
false
gd10cl
Old Feb 16, 2010 | 10:41 AM
Prozon's Avatar
Prozon
They are not limited around here. Lots of Sterlings floating around. And parts arn't all that expensive to buy for it.
So i'd say your friend is wrong.
Old Feb 16, 2010 | 11:15 AM
crazyredneckanyhow's Avatar
crazyredneckanyhow
I believe lockers and such are alot more expensive than say a d60. As far as over the counter stuff it shouldnt cost much more if any than other stuff. Now correct me if im wrong but isnt gear selection more limited than 44/9/60/70?
Old Feb 16, 2010 | 11:23 AM
alpha/omega's Avatar
alpha/omega
Parts are expensive.
Paul is paying me $395 ($190 each for me and Robbie + a case of beer) for an open loaded carrier.
To anyone else they are worth about $40. Pauls just dumb.
Old Feb 16, 2010 | 11:27 AM
crazyredneckanyhow
Originally Posted by alpha/omega
Pauls just dumb.
Best quote EVAAAAAAAAAAAAAAAAAAAAAAAAR!!!!!!!!1!!!!
captain p4's Avatar
captain p4
More false
I tricked you into spending a whole lunch breaking pulling it and I'm not even going to buy it now ! :flipoff2:
ok, maybe I'll still buy it. but not for 400
Old Feb 16, 2010 | 11:39 AM
alpha/omega
Not really a whole lunch break...more like 20min with 2 beer breaks.
Im slow in the head...not with a wrench.
Old Feb 16, 2010 | 01:14 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
I have found the gear selection is more limited than other axles. Same with lockers and LS. I haven't searched for axle shafts. I have had no problems with mine, only problem i have heard repeatedly is occasionally spinning a tube. But that can be fixed with a few strong beads... I haven't really heard of many broken shafts either...
Im happy with mine. I can say when i was pricing gears and lockers, it was about 800 for the rear, i believe that was with a detroit, but dont quote me, it was several months ago.
Old Feb 16, 2010 | 01:45 PM
captain p4's Avatar
captain p4
Isn't there an issue with a shorter pinion shaft on some of the earlier ones?
I also think the stupid dutys blow pinion seals pretty regularly.. but thats a 10.5" sterling
Old Feb 16, 2010 | 02:40 PM
kjett's Avatar
kjett
Now that's a quote to remember! You should make a sign for your garage that says "Short bus ridin and wrenchi"
Old Feb 16, 2010 | 02:59 PM
Truckin4life
Yea i think you are right paul...
Old Feb 16, 2010 | 05:59 PM
dillinewton
ok well now that i can tell my friend he is an idiot, where would be the best place to shop for lockers and and gears for these? thanks alot
Old Feb 16, 2010 | 06:16 PM
crazyredneckanyhow
Welcome to Complete Off Road
Old Feb 16, 2010 | 06:18 PM
alpha/omega
Alright Dillin....crown in hand I will now answer your questions.
As Paul vaguely mentioned (:flipoff there are two "versions" of a Sterling 10.25. Short pinion and Long pinion. The short pinions are from 89-92 and the longs are from 92.5-98. The abbreviated answer is short pinion gear sets are pretty much not available for ratios above 4.10. The long pinion gears sets are available up through 5.38...maybe higher, not sure. If you have a short pinion axle all you need is a long pinion yoke and the appropriate ratio long pinion gear set.
No big deal.
Sterling parts are basically the same price as comparable D70 parts. Maybe a couple bucks here or there more but nothing major. I wouldnt sell a Sterling to buy a 70 if that makes sense.
Tips/tricks if you rebuild your Sterling.
-use a solid pinion shim from a ford 9" instead of a crush sleeve
-use Dana 70 ring gear bolts instead. The 70 bolts have a shoulder that keep them from backing out under load.
-be careful with the diff cover. Believe it or not its the weak link of the axle. If you can find a wrecked 08-10 Superduty ****** the diff cover off. BLING DADDY!
I buy all my axle parts from Rich at Welcome to Complete Off Road. Damn nice guy and extremely smart on axles.
