1978 - 1996 Big Bronco
need front diff help
Old Feb 22, 2010 | 10:47 AM
NWBronco's Avatar
NWBronco
Well said. I just wanted the OP to know that it wasn't a pull it and swap kind of thing. A few other parts need to to swapped.
Old Feb 22, 2010 | 01:04 PM
Kemicalburns's Avatar
Kemicalburns
thats correct NWBronco. if you have all the parts cleand up and ready to go and know how to weld perhaps the job could be done in a weekend with some help. most take a week at least and run about 2k total with the cost of the front diff and getting it to spec
Old Feb 22, 2010 | 04:15 PM
PSYCHO BOB's Avatar
PSYCHO BOB
i appreciate all the help. found out the guy is throwing in the rear axle also. not bad for 50 bucks. what kind of rear axle came in the 90 bronco
Old Feb 23, 2010 | 11:50 AM
Kemicalburns
its an 8.8.
i would take it but not use it. keep your 9" unless its running a 3.08 ratio
Old Mar 15, 2010 | 05:59 PM
PSYCHO BOB's Avatar
PSYCHO BOB
started taking the front end apart. got to the right side axle shafts and can't figure it out. i've looked in the manual and at online write-ups. everything says i'm supposed to remove the clamps and rubber boot. the thing is i don't have any clamps connecting the two axles. here's what i'm looking at.
Old Mar 15, 2010 | 06:01 PM
greystreak92's Avatar
greystreak92
The clamps and rubber boot are done missin' in that thar axle!
Old Mar 15, 2010 | 06:03 PM
PSYCHO BOB's Avatar
PSYCHO BOB
if that's the case aren't the two axle's just supposed to come apart.
Old Mar 15, 2010 | 06:11 PM
greystreak92
I would think so. If my memory serves me. Will the axles simply not come out of the diff?
Old Mar 15, 2010 | 06:12 PM
PSYCHO BOB's Avatar
PSYCHO BOB
the left one yes. the right one no. there's a 'c' clip inside, but the outer right axle i thought should just come apart from the inner after the clamps are removed.
Old Mar 15, 2010 | 08:33 PM
NWBronco's Avatar
NWBronco
Agreed. The passenger side inner is secured by c-clip. The outer should slide right out of the splined end of the u-joint, Is there any play in it at all? May be rusted together. pop it lightly with a hammer and see if it comes apart. Those boots are the worst water collectors I have ever seen.
Old Mar 15, 2010 | 09:32 PM
PSYCHO BOB's Avatar
PSYCHO BOB
it does move in and out about an inch, but won't come all the way out. tried to spray it down with wd40, but didn't do anything. i'll work on it some more tomorrow. good thing i have multiple vehicles. one of my other cars is in the body shop
Old Mar 15, 2010 | 11:50 PM
Encho's Avatar
Encho
The Southernmost Mod
Also... i wouldn't just trust the tags (in trucks this old, pinion and rings could have been swapped), ask the PO to see if they remember the gearing those trannies had, just to be safe.
Old Mar 17, 2010 | 11:07 AM
  #28
PSYCHO BOB's Avatar
PSYCHO BOB
PO? also what does the tranny gearing have to do with separating the 2 piece axle
Old Mar 17, 2010 | 01:07 PM
  #29
NWBronco's Avatar
NWBronco
PO previous owner. And Encho is a post or two behind. He's referencing the axles you bought/are buying earlier. You went from getting the replacements to removing the Dana 44 axleshaft in the same thread, so it happens. I've done it myself.
Old Mar 17, 2010 | 01:10 PM
  #30
PSYCHO BOB's Avatar
PSYCHO BOB
my bad. the guy ended up not being able to drive here and sold the other axles. the PO is a buddy of mine and never even used the truck. it was parked in his back yard for about 5 years when he gave it to me.
dieselsmoker
6.4L Power Stroke Diesel
Nov 18, 2012 06:24 AM
jdboy
Apr 14, 2011 09:11 PM
jjed2007
Oil & Lubrication
Feb 27, 2008 02:47 PM
cravenc
1997 - 2003 F150
Mar 15, 2006 07:55 AM
81fordf-100
Apr 16, 2004 07:54 PM
