Sponsored by: Real Truck
Front Diff. Fluid Change
Old Apr 14, 2011 | 07:13 PM
jdboy's Avatar
jdboy
Question Front Diff. Fluid Change
I would have posted this down in the other section of the forum but it looks as if nobody ever replies to anything! I have a 2003 Super Duty and I'm looking to change all my drive line fluids. I have Royal Purple for the rear diff. and transfer case but neglected to order any fluid for the front diff. What are you guys running when doing the front diff. fluid change. The manual calls for SAE 90 Hypoid but I'm not having any luck finding a good compatible fluid. I figure since I'm going with good fluid everywhere else I'd like to put something good in the front diff. as well! I seen one tech. article and the guy used 75w90 but I'm unsure how this compares to the 90w. Any help or suggestions on this would be great!!
Old Apr 14, 2011 | 07:23 PM
1975StroppeBaja's Avatar
1975StroppeBaja
I used Red Line 75W90NS in mine.
More info here: 2004 F250 Front Diff Oil Change
Old Apr 14, 2011 | 07:29 PM
jdboy's Avatar
jdboy
LOL, thanks for posting. You're actually the person I mentioned in my first post. I have your tech. articles bookmarked, tons of help. I just wasn't sure since I went to the Amsoil website and it stated the 75w90 was a good replacement for 75w90 but the manual calls for SAE 90. Sorry to sound like a goof but I don't really know how different the two are compatibility wise.
Old Apr 14, 2011 | 07:34 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty
I use SAE Motorcraft (75W-90 I think) gear oil in my front diff, but I also get a discount from the dealership, just personal preferance. There's cheaper and prolly better stuff out there. I changed my front & rear diff at around 60K when I put my 08 rear diff cover on, I also changed the transfer case oil but I used Amsoil ATF for that. No problems so far, and im at 83K now
Old Apr 14, 2011 | 07:38 PM
barthel's Avatar
barthel
Valvoline Duralube 75W-90, only because RP is WAY too expensive.
Old Apr 14, 2011 | 08:16 PM
1975StroppeBaja
Haha.. whoops I didn't catch that in your first post
My manual actually calls for 80W90 and I couldn't find that anywhere and almost every post I found on here said to use 75W90 so I went for it. I believe the "NS" suffix in the part number indicates "no friction modifier"
Old Apr 14, 2011 | 08:31 PM
jdboy's Avatar
jdboy
Cool, thanks again for posting. I'll probably end up going with the 75w90 like you did unless I can find a compelling reason not too.
Old Apr 14, 2011 | 09:11 PM
5.4f250sd's Avatar
5.4f250sd
yep i am running 75 90 amsoil! works great
Firefighter 1406
Oct 20, 2016 02:50 PM
newfie4ever
1997 - 2003 F150
23
Jun 20, 2016 08:04 PM
eagle1030
Jan 15, 2016 11:57 AM
Thumper47
1983 - 2012 Ranger & B-Series
Nov 8, 2011 11:27 PM
pdqford
Jun 11, 2011 08:52 PM
