New gauges installed (pics)
Old Feb 22, 2010 | 04:20 PM
housedad's Avatar
housedad
I just love the jet cockpit look! Too cool!!
Old Mar 1, 2010 | 10:05 PM
riverratmike's Avatar
riverratmike
great job on the gauges. They look awesome. I just got mine in the mail the other day. Same deal as yours but with only three gauges. How did you end up hooking trans sensor? I'm kinda up in air about what I need to do with that 1/8 NPT sensor and where I should install it into the trans.
Old Mar 2, 2010 | 08:22 AM
dvldog458's Avatar
dvldog458
Thanks guys.
As far as the trans sensor I just used thr pre drilled hole in my Mag-Hytec pan. I unscrewed the plug and threaded the sensor in. I think you can tap into the stock trans sensor wiring harness. This way you don't have to remove your stock pan and drill it for the sensor.
Old Mar 2, 2010 | 10:46 AM
blowhole's Avatar
blowhole
Installing the trans sensor is the easiest of all three (boost, trans, egr). The sensor 'port' is already there, just remove the bolt and install the trans sensor with a tad bit of lock-tite! Done.
Old Mar 2, 2010 | 11:37 AM
ZaksEx03's Avatar
ZaksEx03
I have a three gauge system in mine. personally i prefer the white faced auto meter gauges but to each his own. looks nice though love the four guage pod might need to get me one
Old Mar 2, 2010 | 12:14 PM
OutlawNomad's Avatar
OutlawNomad
It looks really good
Old Mar 2, 2010 | 12:18 PM
Stewart_H's Avatar
Stewart_H
Don't do that. Just remove the service (test) port plug on the drivers side of the trans and screw the trans sensor in there.
Also, like I posted in post #10 above, the temp won't be the same if the sensor is installed in the pan instead of the trans.
Stewart
Old Mar 2, 2010 | 04:42 PM
Skip1970's Avatar
Skip1970
Just installed new Glow Shift gauges and an Autometer pillar.
I usually use Autometer gauges...but I wanted to try something new.
I installed a EGT (into exhaust manifold),Trans temp (probe in Mag-hytec pan),Boost pressure, and Volt meter.
For an EGT gauge...what is a normal/average temp I should be seeing?
Also what should I be looking for on the trans temp gauge?
How much $ did all that cost?
Old Mar 2, 2010 | 04:54 PM
dvldog458's Avatar
dvldog458
Just under $250 for all four gauges. I did the install my self so there were no labor charges
Old Mar 2, 2010 | 05:04 PM
Skip1970's Avatar
Skip1970
that include the 4 pod pilar? if so that a good deal! where u get them from so i can get sum, oorah!
Old Mar 2, 2010 | 05:21 PM
dvldog458's Avatar
dvldog458
Sorry. I forgot to include the pillar in the total. I think I paid $85 for it. I bought it from a guy on Ebay selling them already painted. Semper Fi.
Old Mar 2, 2010 | 06:47 PM
riverratmike
and where is this port located on the trans?
Old Mar 2, 2010 | 07:32 PM
  #28
Stewart_H's Avatar
Stewart_H
Courtesy of ITP Diesel: http://www.itpdiesel.com/other/7.3L%...structions.pdf
Scroll down to figure 15 almost all the way to the bottom of the page, third to last picture.
Stewart
Old Mar 2, 2010 | 08:36 PM
  #29
dvldog458's Avatar
dvldog458
Nice link!
Old Mar 2, 2010 | 09:15 PM
  #30
OutlawNomad
Nice link!
Woodbridge NJ HUH - Edison here!
Now I know where to go when I need interior help
