New gauges installed (pics)
#77
Exactly which gauges to buy...
NEVERMIND on this section, I found dvldog458's answer here.
<DEL>dvldog458 or someone else that would know...</DEL>
<DEL>
I have a 2005 EX EB 4WD 6.0L and need to know which gauges to buy as far as what ranges some include. Here is what I am looking at for the 4 gauge pillar...
</DEL>
dvldog458, I saw that you bought the tan pillar and would ASSume that you have the tan/beige interior, how did it match up? I have the Eddie Bauer beige/brown interior and was curious if it blended well.
Thanks in advance...
<DEL>
- EGT - Exhaust Gas Temp Gauge 1500 F or EGT - Exhaust Gas Temp Gauge 2400 F?
- Boost / Vacuum Gauge, 35psi Boost Gauge, 60psi Boost Gauge or 110psi Boost Gauge?
- Trans Temp Gauge (even though I have the stock one)
- Volt Gauge
</DEL>
#79
#80
<del>dvldog458 or someone else that would know...</del>
<del>
</del>
<del>
- Volt Gauge
</del>
New codes are coming out all the time for these units to see just about anything accessible from the OBDII port/PCM.
EGT's will still have to be watched with a pyro, and fuel pressure will still need a separate gauge and sender. For untuned trucks a ScanGuage II and fuel pressure gauge are mandatory equipment AFAIC.
#81
Most of the info that's out there regarding 6.0l EOT/ECT temps is based on what's seen by the PCM using the factory sensors. Any other location will give you different results/data. The only way to display PCM data accurately is with something that plugs into the OBDII port.
duphofff
12-21-2011 05:49 AM
Spool&Go
203
12-16-2011 08:32 AM
Waltdog
25
12-29-2010 04:48 PM
