rebuilt cylinder heads
Old Feb 15, 2010 | 09:12 AM
ehgeeray's Avatar
ehgeeray
I am planning to remove the heads on my 6liter and send them to be rebuilt... Does anyone have any recommended shops? I will send them by mail... I'm just looking to have them reconditioned not modified
Old Feb 15, 2010 | 09:55 AM
cartmanea's Avatar
cartmanea
Do they have a ton of miles on them? Just wondering why you're having them rebuilt. Usually you just pull them, check for flatness, and reinstall.
Old Feb 15, 2010 | 10:27 AM
ehgeeray's Avatar
ehgeeray
I figured I would have them checked over more thoroughly so I didn't have to take them off again. there is only 75k mi on the truck...
Old Feb 15, 2010 | 10:36 AM
cartmanea's Avatar
cartmanea
Have them checked for flatness, cracks, and pressure test the valves, but don't worry about rebuilding them unless there are obvious problems.
Old Feb 15, 2010 | 04:23 PM
ehgeeray's Avatar
ehgeeray
that is what i will do...
Thanks for the advise
Old Feb 15, 2010 | 06:43 PM
cheezit's Avatar
cheezit
it may just be cheeper to buy a stright edge and some feeler gauges. to test the valves for leakage just fill the ports with water and check the valve face for wetness.
clean heads with metal serface prep and approved scrapper
Old Feb 17, 2010 | 03:13 PM
ehgeeray's Avatar
ehgeeray
Can I soak the heads in a parts washer for cleaning? Will this damage the adhesive used to glue the injector and glow plug sleeves?
What is considered "An Approved Scrapper" what about a wire brush would that work?
Old Feb 17, 2010 | 06:28 PM
cheezit's Avatar
cheezit
plastic scraper and metal prep cleaner. the cup are put in with 262 locktite.
dont use wire brush.
Old Feb 17, 2010 | 07:58 PM
ehgeeray's Avatar
ehgeeray
Thanks Cheezit.
I looked up Loctite 262 and It appears to be resistant to everything.. Gas, oil, acetone , ethanol etc etc etc...
Old Feb 18, 2010 | 12:22 AM
cartmanea's Avatar
cartmanea
Cheezit, I tried giving you Reps, but apparently I haven't Rep'd anyone else since last time I did to you, so it won't let me.
Old Feb 18, 2010 | 04:23 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Got him for ya cart
Old Mar 20, 2010 | 05:19 PM
ehgeeray's Avatar
ehgeeray
I am currently trying to clean the engine deck where the heads sit. I have the motocraft metal surface prep cleaner. I applied the metal surface cleaner and left it for a few minutes. It doesn't seam to make any difference.... I understand I shouldn't use a wire brush but what about a brass bristled tool for a dremel tool? Can I use a scotch bright bad? what about a razor blade?
currently there is old gasket material, hard black crust and rust near the coolant holes. Is the metal surface prep suppose to remove all of this? I assume I want the deck to be perfectly clear?
Old Mar 20, 2010 | 06:44 PM
cartmanea's Avatar
cartmanea
I would use a good gasket scraper first that won't dig into the block, then use the cleaner and maybe some surface cleaner 3m pads for a drill or rotary air tool as a final prep.
Old Mar 20, 2010 | 06:52 PM
cheezit's Avatar
cheezit
keep one thing in mind when doing this the idea is to have a clean area, there is no need to remove stains from the sealing serface as doing so is also removing metal.
the act of removing metal will change the RMS of the part you are working on.
jrockdiddy
Jul 23, 2015 09:44 AM
PRUSue
Jul 21, 2014 06:39 AM
rpatrick
Sep 10, 2012 05:57 AM
Devore95
Apr 22, 2012 11:03 PM
ackusackus
Jan 16, 2002 11:30 AM
