IDI project
Other Stuff-Roof Sun Visor, West Coast Mirrors, Bug Deflector, and One Huge Fuel Tank (No Fuel Selector Valves to Fail), On Board Air, Air Conditioning, Hydroboost Brakes,
6.9 - Manual Glow Plugs, 7.3 Rockers, 7.3 IDI Turbo Injector Pump and Injectors, 7.3 IDI Fuel Filter Header, Head Studs, Intake Studs, Turbo, Ram Air, Soup Bowl Delete, Rebuilt Oil Cooler, Plumb in a Tank-Type Block Heater (Tank-type Engine Heaters - JCWhitney), 3" Exhaust, type4 camshaft (just read about it)
E4OD - Consult David85! I can't find the thread I was reading that he was listing his work. But what comes to mind: BIG cooler, stand alone harness, and some steel planetary gear upgades(?), manual TCC (?),
BW1356 - New Bearings and Seals, Check chain for stretch,
Dana 60 - 3.55 Gears, ARB Air Locker, New Bearings/Seals, New Brake Calipers/Pads/Hoses/Rotors
Ford 10.25 - 3.55 Gears, ARB Air Locker, 2nd Generation Pinion/Yoke, 3-Gear Spyder Setup, Dana 70 Shouldered Ring Gear Bolts,New Brake Drums/Shoes/Wheel Cylinders/Hardware Ford 10.25 & 10.50-Inch Axle Tips - Four Wheeler Magazine
Chassis-Nice Big Rear 2" Receiver Hitch, Simple Heavy Duty front bumper with 2" receiver and D-Rings
Star-If all else fails, throw one of those "Performance Chips" at it!
To bad you don't have your Lincoln anymore, slap that 460 in there and get rid of the ****ty gutless 302!
What ever I do there won't be any place for a chip. lol
I could use a cummins but I would like to build a 6.9 up and keep it all ford, just use all the best stuff ford has. lol
also I'll show u those pics of the new rims they are sweet!
Banks has a chip for the E4OD that's supposed to give better, crisper shifts.
With 4.10 axle gears, .71 E4OD Overdrive, and .78 GV OD-your effecive ratio is 2.66. At 2500 RPM with 31" tires, you're at 102 MPH in Double-OD.
Here's a nice chart - Gear Vendors Under/Overdrive Ford Truck-Car-Van 2-Wheel Drive 4-Speed and 5-Speed Automatics.
4.56 axle gears, and double OD puts you at 2.51 effective ratio. At 2500 RPM with 31" tires you're at 92 MPH.
3.55 axle gears: double OD puts you at 1.95 effective ratio. At 2500 RPM with 31" tires you're at 118 MPH.
I put 3.55's in there because when we took our cross country vacation, we drove through New Mexico and it was pretty flat. I figured you do a lot of open-range driving, and that you could just shift into 4lo for lower gears. I don't know that 3.08's are available for the front Dana 60, Otherwise I would have put those in the list.
What are you using the truck for Star?
I am leaning on 4.56 gears if I can stay at or under 2000 at 70 I would be happy.
I will be checking to that type 4 cam though If I can get the power at 16 I would be happy. Also I stay in alaska more than here and plan to stay there all the time before long, so when I go any where I get into all kind of terrain and some of it serious hills, flat ground is too boring.
haha
