360 intake choices
Old Feb 14, 2010 | 03:52 PM
jdenison75's Avatar
jdenison75
360 intake choices
Just got a 72 f 250 with a 360. I can only find one aftermarket aluminum intake and thats the edelbrock. Are there any others, and do any other engine sizes like a 390 intake fit? I looked on ebay for a 4v intake and cant find anything other than the edelbrock.
Old Feb 14, 2010 | 04:30 PM
Bear 45/70's Avatar
Bear 45/70
If you want a 4 barrel intake for your 360, the cheap and smart way to go is to find a Ford iron "S" or "T" 4 barrel manifold. Cost a lot less, allows you to run the 4 barrel (keep it under 600 CFM and NO mechanical secondaries) all the gain you will get from the aluminum intake is saving 50 lbs of weight and in a truck that just isn't gonna make much difference.
Old Feb 16, 2010 | 08:28 PM
fordeverpower's Avatar
fordeverpower
yeah bear has a point but the edelbrock rpm is nice unit and will leave room for future improvements. The regular performer is nothing special, there are other intakes out there, most are single plains or dual quads.
Blue Thunder is a real pricey intake.
Old Feb 17, 2010 | 05:06 AM
jowilker's Avatar
jowilker
Anything for a 390 will fit your 360, since it is a 390 block.
John
Old Feb 22, 2010 | 04:39 AM
CheeksMcDuke's Avatar
CheeksMcDuke
Try DSCMotorsports.com the have a lot of good stuff for the FE and I would suggest picking up a 390 and swapping it out in place of the 360 as the 390 is rated at anywhere 315 @ 4600 rpm with stock 4V induction. The 360 is only rated at 215 Hp @ 4200 rpm with stock 2V Induction. I found several low-milage runners in my area for 400-600$ and core motors complete pan to carb for as low as 75$...just a thought...If your engine is getting tired, Summit racing has re-ring kits and full engine kits complete with pistons ford just under 400$. Bit of a mouthful but I hope I helped.
Old Feb 22, 2010 | 09:43 AM
Bear 45/70's Avatar
Bear 45/70
Another beleiver in the horsepower lie. On the street and in a lot of racing venues, torque is way more important.
360 327 @ 2400
390 427 @ 2800
Horsepower is top speed and does nothing for acceleration and the all important low end grunt.
Old Feb 22, 2010 | 03:06 PM
CheeksMcDuke
360 327 @ 2400
390 427 @ 2800
My point still stands, though. I am aware that horspower is for top end, I just like to go fast. Thats why i posted that. But thank you for clarifying.
Old Feb 22, 2010 | 06:04 PM
Bear 45/70's Avatar
Bear 45/70
You really don't know what fast is do you? Oh and 70, 80 or even 100 mph is not fast. Also there is nowhere on the public streets to go fast anymore without endangering others. I really don't care if you endanger, injury or even kill yourself, but when you do it to others I have a major problem with it.
FYI, I have probably been faster on the water than you have been on land. I know I've been fast than you in the air.
Old Feb 22, 2010 | 10:04 PM
CheeksMcDuke
Well this is the last time i'm getting into a pissing contest online so i won't be replying to this post again....I DON"T GIVE A RAT'S A$$. Thats real nice, good for you...If you were here I'd give you a whole box of frikin cookies for your land/water/air speed acheivments. So you're cooler than me, you're just an awesome dude, I get it.
I was trying to offer up some advice but if all thats going to do is get me ***** on then its not gonna happen anymore.
Cheeks
P.S. Is 173 mph on an abandoned airstrip in my Galaxie fast and secluded enough for you?
Old Feb 22, 2010 | 10:57 PM
Bear 45/70's Avatar
Bear 45/70
Cheeks
Well I will give you this you are an A$$. I also doubt that unless it was a 427 and the car was stripped, that you actually went that fast. Mainly because my 1969 428CJ Cobra which is 5 times more aerodynamic and a bunch lighter than your Galaxie wouldn't go that fast, even with 3.00 to 1 gears in the rearend. But then you internet heros are all that way.
Old Feb 23, 2010 | 03:52 AM
jowilker's Avatar
jowilker
Ya gots to love in state rivalry.
John
Old Feb 23, 2010 | 11:28 AM
Bear 45/70's Avatar
Bear 45/70
John
Yeah, but he had been radiated by being are nuke subs and missiles.
Old Feb 26, 2010 | 05:51 PM
George Frasier's Avatar
George Frasier
Good humor seen here. . . ( "Mine's BIGGER than yours' ) < under a "looking glass' anyway.
MY question is : who ALSO uses a pair of tweezers also ???
Old Mar 1, 2010 | 02:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Your 360 vs 390 HP figures are misleading.
The 390 4V 315 HP engine was not available in F100/350's. Optional in Passenger Cars, Ranchero's only.
Ford did not offer a 390 with a 4V in F100/350's until 1974.
Old Mar 1, 2010 | 03:05 PM
George Frasier
Whatever fits the 390 will fit the 360. There's a LOT of info on the "net" about the 'FE' engines m- just takes a bit of looking around to find the solution that fits YOU. ( On your 'explorer' - type in "Ford FE engines" and you can find a library. Look into the earlier 390 Ford cars for 'that one' that works for you.
angeloa
20
Sep 2, 2016 09:51 AM
GamerGirlAlice
Jan 17, 2013 11:15 PM
maxtor
Jun 28, 2008 02:10 PM
Fordman360V8
23
Jul 22, 2005 12:55 PM
jdawg78
Jul 9, 2002 07:08 AM
