I got a 72' 360 engine
Old Feb 13, 2010 | 09:34 PM
charles09's Avatar
charles09
seems to have a big mis fire i think its due to timing or the carb I bought a new fuel pump that fixed the issue of hitting the accelerator and it dieing now it sounds awful when i give it a rush amount of fuel holding the pedal to the floor. Idk whats wrong with it?
Old Feb 14, 2010 | 06:07 PM
Gear Up's Avatar
Gear Up
Ford carbs have a tendency to have problems with the Accelerator pump and the power valve. They are both found in the same area of the carb. The accelerator pump is found on the front left corner of the carb and it takes four screws to remove it and put the new one in place. The power valve is directly under it on the bottom side of the carb; again you remove four screws to get the cover off and the remove the old valve and reverse the process the install the new one. If you can find a tag on one of the front screws holding the top of the carb in place take it to you auto parts store and get the appropriate carb kit and rebuild the carb. The ford two barrel is one of the most straight forward carbs and when done you should see a marked difference in the running of the engine.
Gear Up
Old Feb 14, 2010 | 06:12 PM
charles09's Avatar
charles09
alright i'm thinkin about getting a new one it says motorcraft on it so I'm gonna try that name!
bmacky14
Jun 2, 2013 05:59 PM
mechelement
Nov 21, 2011 07:41 AM
terryq
2004 - 2008 F150
Oct 31, 2010 07:41 PM
propaneman
May 29, 2008 11:51 PM
vaultster
Mar 19, 2007 07:19 PM
