Sponsored by: Real Truck
obd 1 or 2
Old Feb 13, 2010 | 07:19 PM
jakazz007's Avatar
jakazz007
obd 1 or 2
So I have been lurking here and getting good info, what I'm wondering is the scanner thing. I read here that a truck over 8900 uses a obd1 system, but is it still readable with an obd2 scanner?
Hey I'm a noob, and dont want to goto the stealership anymore......
Old Feb 13, 2010 | 07:44 PM
Darrenigel's Avatar
Darrenigel
Yes it uses an OBDII scanner
Old Feb 14, 2010 | 06:53 AM
jakazz007's Avatar
jakazz007
Sorry i didnt say its a 2002 f-350 with a 5.4, does this still work with the obd2 reader?
Old Feb 14, 2010 | 08:17 AM
_Rick_'s Avatar
_Rick_
Jak,
Your '02 should be (is) OBD II. If you want to be 100% sure,,, look at the vehicle emission sticker under your hood near the latch catch. This should confirm it for you.
Below in an example of the sticker for you which happens to also be a 2002 F350 but a 6.8 US vehicle
You'll notice near the bottom of the sticker it states its OBD II certified.
https://www.ford-trucks.com/forums/p...ictureid=15447
Rick...
Old Feb 14, 2010 | 11:50 AM
jakazz007's Avatar
jakazz007
Actually I checked and it says heavy duty vehicle, instead of medium duty, and no obd2 compliance stated
Old Feb 14, 2010 | 12:51 PM
_Rick_'s Avatar
_Rick_
There I go taking things for granted again.
Regardless,,, The better OBD2 readers are generally backward compatible with OBD1 systems so that answers your main question.
Maybe the link below will help you confirm if your truck is 2 or 1
(OBDII pin layout)
I would be surprised if your truck is not OBD2. But I've heard and seen stranger things.
I'm sure someone will stop by here soon enough to confirm either way.
Rick...
Old Feb 14, 2010 | 02:41 PM
Furian's Avatar
Furian
You Keep What You Kill
All cars and trucks sold in the USA since 1996 are OBD2 compliant. See link below...
OBDII - On-Board Diagnostic's System - Does My Car Have OBD-II? The Connector and Communications.
Old Feb 14, 2010 | 03:20 PM
06silvercrew's Avatar
06silvercrew
This is correct in my mind, however there will be people in here shortly to disagree. This was brought up in a debate awhile back on here, about some of the 7.3's with a higher GVWR. However in my 13 years as a tech, I have NEVER laid eyes on one.
But to answer the OP question, your truck without a doubt is OBDII
Old Feb 14, 2010 | 05:00 PM
RentAMan's Avatar
RentAMan
Talking OBDII or I
The guys above gave you correct and good information.
All vehicles after 1996 should be OBDII.
A good scanner (they usually cost about $200-$300),
will cover all models.
Or go to your local Autozone and get it done for you free.
Just a thought to save some money.
Jaime74656
17
Dec 26, 2011 08:09 AM
jbrown9709
Feb 20, 2011 04:07 PM
Firefighter 1406
Jul 19, 2010 02:55 PM
KT987
Dec 11, 2009 12:01 PM
ranger6
Jun 14, 2003 11:29 AM
