95 OBD2?
Old Feb 20, 2011 | 02:48 PM
jbrown9709's Avatar
jbrown9709
95 OBD2?
Hi,
I'm asking about a recently acquired 95 F350 crew powerstroke. I've read multiple conflicting information on this site and others about whether the obd2 plug is enabled in 95 trucks. Is there are serial number break where older is obd1 and newer is obd2? Perhaps a simple test is possible, short of buying a scanner and plugging it in to the obd2 port and just trying it?
Thanks,
Jeff
Old Feb 20, 2011 | 04:07 PM
RRranch's Avatar
RRranch
If it has the EEC4 connector by the left hood hinge then most likely it isn't. It may have been reprogrammed though. I always reflashed the PCM's on those at all the ford dealers I worked at whether it needed it or not. They were much easier to diagnose that way. There should be a sticker somewhere on the radiator support or door jamb if a dealer did that. If you do have the eec4 connector then the only way to know if the obd2 dlc works is to try it. If it will get a datastream then it should be fully functional.
mike21105
1983 - 2012 Ranger & B-Series
Sep 8, 2016 02:18 PM
xc4jokestomper
18
Aug 6, 2015 01:03 AM
frankyford
Jul 27, 2009 02:08 PM
60RatRod
Aug 9, 2008 10:01 AM
BOB ROSS
1978 - 1996 Big Bronco
Oct 25, 2006 06:32 PM
