Which line to plug for Warn locking hubs.
Old Feb 13, 2010 | 04:38 PM
maevans's Avatar
maevans
I replaced my OEM locking hubs with Warn hubs last spring and last week was the first time I needed to used 4x4. When I did switch it to 4x4 the dash heat went to defrost. That when I realized that I didn't plug the vacuum line under the hood near the vacuum pump. After plugging the line I still have the same problem of switching to defrost when I engage the 4x4.
Does anyone have a pic of which line I need to plug under the hood. or what else I may need to do to fix this.
My computer crashed last week and lost every think I saved for FTE.
Old Feb 13, 2010 | 04:47 PM
big poppa's Avatar
big poppa
Hey Mark, I know you can plug the ones going to your hub, put a screw in the line of sorts and cap off those fittings with a plastic-rubber cap, that should do it. Sorry to hear about your computer, mine did the same thing two weeks ago, clicked on a link and everything went nuts.
lifted77f250's Avatar
lifted77f250
You can cap them down at each wheel were they transition from hard line to rubber. You need four caps two for each side. remove the soft rubber line that runs from the hard line down to the wheel assembly. Place a cap on the hard line and one on the fitting on the wheel assembly.
I have a attached a link to a picture of the vacuum system in the engine bay. You can disonnect the line from the solenoid and cap that line instead of doing down in at the wheels.
http://i268.photobucket.com/albums/j...acummLines.jpg
There maybe a better way to do this or a more correct way. try doing a search if you haven't already, there are a ton of posts on this topic.
Old Feb 13, 2010 | 04:50 PM
PaysonPSD's Avatar
PaysonPSD
Here's the pic I made up. The Vac Line To Hubs goes to a 90 degree elbow.
Pull apart there and plug line that goes back to the Vac Reservoir as
well as the one that goes to hubs (to keep out moisture and crap).
Edit : Lifted77 beat me to my own pic.
I wish I had spelled vacuum properly.
Old Feb 13, 2010 | 04:53 PM
maevans's Avatar
maevans
But wouldn't capping the line under the hood do the same thing Mike ?
The link just send me to photobucket sir, no pic of the air line to cap.
Old Feb 13, 2010 | 04:56 PM
PaysonPSD's Avatar
PaysonPSD
Mark,
See my post just above yours.
That's my Photobucket. If you lost the link PM me.
Old Feb 13, 2010 | 04:58 PM
maevans's Avatar
maevans
Ok.. in your pic, The line marked Vac line to hubs is the one I plugged at the 90deg elbow. and the heat still blows threw the defrost when in 4x4
Old Feb 13, 2010 | 05:02 PM
PaysonPSD's Avatar
PaysonPSD
Well that's not right. That is where mine is plugged due to a hub leak and mine doesn't default. Check the HVAC Vac Line. Make sure it is tight at both ends, and the double plug at reservoir is OK.
Old Feb 13, 2010 | 05:05 PM
Ponyboychris's Avatar
Ponyboychris
That was my thought as well, the leak must be upstream from the 90 degree elbow. I capped off the lines at the hubs in the wheel wells with no issues when I switched to the Warns. Good luck.
Nice pic, need to save that one.
big poppa's Avatar
big poppa
Yep, looks like Robin and lifted77 got you, great diagram Robin has. The way I said to cap it is just a fix now, you can get more creative and do a nice job like Robin posted..
Old Feb 13, 2010 | 05:10 PM
PaysonPSD's Avatar
PaysonPSD
Mark & Mike,
OT side note: External backup hard drives with software that backs things up automatically are dirt cheap these days. Plug and play.
Also, the closer to the reservoir you plug the line the simpler it is and less chances of a problem.
Mark,
Make sure pump runs when you release vac from the res.
Old Feb 13, 2010 | 05:16 PM
maevans's Avatar
maevans
Mark & Mike,
NOW YOU TELL ME...
Old Feb 13, 2010 | 05:22 PM
PaysonPSD's Avatar
PaysonPSD
NOW YOU TELL ME...
I just found out you didn't have one.
megawatt00's Avatar
megawatt00
These guys have you headed in the right direction. Glad to see that you are back online.
Old Feb 13, 2010 | 05:31 PM
PaysonPSD's Avatar
PaysonPSD
Howdy Jim.
