Who is using NON-modified B code springs?
Old Feb 20, 2010 | 09:27 PM
Forest's Avatar
Forest
Originally Posted by Stewart_H
Just use the OEM 2" block and add the RAS, you should be golden!
Stewart
B code springs with 2" block AND RAS? Won't I have driveline angle problems? Seems like the addition of RAS will make the driveline angle even more severe. I can try it...but it sure is a lot of work.
Has anyone tried this combination?
Old Feb 20, 2010 | 11:47 PM
Stewart_H's Avatar
Stewart_H
OEM 2" plus the RAS should put you right about where the 3.5" tapered block would be.
I think anymore lift that that and the pinion angle might be out of optimum, but I'm basing that on others who have posted vibration occuring after using a 4" square block.
Stewart
Old Feb 21, 2010 | 10:47 AM
Forest's Avatar
Forest
Sorry--I was not clear.
I have already installed the V,B code springs. B code springs on the rear along with the 3.5" tapered block.
I have 2 concerns:
1) The rake of the truck is a bit much without load (about 1.5" higher in rear than in front).
2) Since I tow heavy, I'm seriously considering ALSO adding the RAS for the rear springs. I actually have already tried this and the rake becomes more like 2.5" and the Excursion will no longer go into our garage. The RAS springs are sitting on my workbench while I decide what to do.
If I could lower the rear about 1.5" and then add the RAS, it seems that I would have an ideal combination for towing heavy. But...I am really worried that my driveline angles would be too far off with a straight 2" block.
So, my question remains...does Ford make a tapered 2" or 2.5" block for this application? Or is there another way to correct driveline angle?
Old Feb 21, 2010 | 12:32 PM
Stewart_H's Avatar
Stewart_H
You were clear bro.
Do you still have the OEM blocks that came on your Excursion? If yes, drop back down to those and add the RAS. See how that drives and tows. See if there is any vibration. I'm betting you will probably be ok, based on the information guys have posted here over the years with their slightly divergent modifications, as well as my own experience.
Even though the OEM block isn't tapered, I'm betting you will still be within the optimum range for your Excursions pinion angle.
I know it's a lot of work, but since you already have all the parts right there, it's a sure fire way to see if the OEM block, B code spring, and RAS will work ok!
Stewart
Old Feb 21, 2010 | 09:37 PM
Forest's Avatar
Forest
Stewart--Thanks for the advice. I think I'm going to try it. I've got all the parts, including original U-bolts (that I would replace with new after checking).
Taking the family to DisneyWorld in March. Trying to get everything set up just right. I've actually only towed about 20 miles with the 2005 (and V/B set up). It seemed OK, but I'll be adding Hellwig and maybe the RAS before we go in 3 weeks. Stability is king when towing in a cross-wind.
Now, if it would just warm up a little bit...
Old Feb 22, 2010 | 09:43 AM
MagKarl's Avatar
MagKarl
You were clear bro.
Stewart
I've see you post this a couple times now. My factory blocks are tapered. Would be interesting to know how much taper the various blocks have in order to keep pinion angles good.
Old Feb 22, 2010 | 11:32 AM
dave91gt's Avatar
dave91gt
Mine vibrates with either tapered 3.5 blocks or factory blocks......
Sorry. Had to say it.
Old Feb 22, 2010 | 12:29 PM
Stewart_H's Avatar
Stewart_H
Really? Wow! First I've heard about factory 2" blocks being tapered. Mine weren't, and way back when I did this mod, everything I read on the different forums stated the OEM blocks were square.
Thanks for posting that. I's good to know that exist...good info to have for others.
Stewart
Old Feb 22, 2010 | 12:32 PM
Stewart_H's Avatar
Stewart_H
If your suspension is still factory stock then it's not your pinion angle.
Stewart
Old Feb 23, 2010 | 08:53 AM
Wild_MN's Avatar
Wild_MN
So, I have modded f-code springs and really could use a two inch tapered block. The above poster says his are tapered can anyone confirm a part number? I have had an 02 and 03 excusrion and only square blocks. Anyone make a 2" tapered block that will not alter the excursion ride height?
Old Apr 4, 2010 | 09:31 PM
nyvp's Avatar
nyvp
sorry to jump in ...have a 03 6.0 limited and wanted to put in a 34.7 tire (325/50r22) would the V + B be enough? I dont really want to move up to a 4"
Old Apr 5, 2010 | 09:14 AM
Macmathews's Avatar
Macmathews
No
IMO - you will rub !
Kyle
Old Apr 5, 2010 | 09:43 AM
  #28
nyvp's Avatar
nyvp
so what do you think i would need to add to the V+B to fit 34.7 ?
Old Apr 5, 2010 | 02:45 PM
  #29
Stewart_H's Avatar
Stewart_H
Depending on the tire, you'd rub a tad on full lock with 315's.
X codes on the front might give you enough space, but you'd have to search the forums and see if it would work.
Stewart
Old Apr 5, 2010 | 05:37 PM
  #30
bjis's Avatar
bjis
Ok got a 2000 4x4 V-10 285-70-16 138,000 miles and the front spring are so bad they arch the other way. What swap should i do all around to get it riding good when i tow the bobcat and camper both close to 10,000 pounds cause trust me its like a tank and in all 3 lines lol thanks for the input. dont care bout the size of tire i need new ones lol
