need help 1995 7.3 powerstroke
Old Feb 12, 2010 | 02:39 PM
hoss95's Avatar
hoss95
i have a 1995 f250 5 speed and here lately when i get to 55mph and just give it enough gas to stay at 55 it vibrates really bad seems like its coming from right underneath my seat i can give it more gas or let off the gas and it will stop it just started doin this couple days ago all the ujoints look good i changed the tranny fluid idk what else it could be your all help would be highly appreciated
Old Feb 12, 2010 | 03:01 PM
plgebbia's Avatar
plgebbia
Do you have a single mass or dual mass Flywheel,
And does it vibrate in 4th and 5th gear, or just 5th gear.
Old Feb 12, 2010 | 05:34 PM
hoss95's Avatar
hoss95
i have no clue bout the flywheel but just in 5th at 55 i can let off and no vibrations or give more gas no vibration just when i barley give any throttle its pretty bad vibration
Old Feb 12, 2010 | 06:59 PM
plgebbia's Avatar
plgebbia
How many miles are on the truck/tranny?
Because you say it is in 5th gear only I would guess it is a tranny problem.
Did it start all at once or has it been slowly getting worse?
Old Feb 12, 2010 | 07:09 PM
Krisx125's Avatar
Krisx125
Drive shaft?? unbalanced?
Old Feb 12, 2010 | 08:48 PM
helifixer's Avatar
helifixer
try running your engine at the same rpm in 4th gear as it is in 5th at 55 ie if in 5th at 55 you are at 2100 run 2100 rpm in 4th gear and see if the vibration is there also
Old Feb 12, 2010 | 08:58 PM
helifixer's Avatar
helifixer
wrong post! oops
Old Feb 12, 2010 | 11:23 PM
hoss95's Avatar
hoss95
well tonight i drove he truck alot n every gear was vibration even slowing down with the foot off the gas it was vibrating its gotten worse in a day what could this be please help
Old Feb 12, 2010 | 11:47 PM
helifixer's Avatar
helifixer
2 wheel drive or 4 wheel drive?
if 4 wheel drive and not used too often could have one hub locked in and spinning the drive shaft! or worn out or frozen u joints on the axle shafts.
have you checked front wheel bearings? jack up each side and rotate the tire, then try rocking the tire up and down.
have you checked the front brakes? i did a brake job on a truck one time and the rotors were worn all the way through the discs and the pads were riding on the cooling vanes, that caused a vibration.
center support bearing on drive shaft.
input pinion on rear end, flange nut can come loose and let the pinion run back against the 3rd member.
carrier bearings on 3rd member
and don't forget a tire with the belts separating. jack up each tire ans slowly rotate and watch the tread for shifting sideways and high spots.
Old Feb 12, 2010 | 11:49 PM
helifixer's Avatar
helifixer
also post up where you are, there are a lot of people here on FTE who will go out of their way to help someone out.
Old Feb 12, 2010 | 11:51 PM
helifixer's Avatar
helifixer
and welcome to FTE
Old Feb 12, 2010 | 11:55 PM
hoss95's Avatar
hoss95
im in barbourville kentucky and its 4 wheel drive ive checked both hubs there on free i checked all ujoint theres no slack or movement it jus keeps gettin worse tho reckon its tranny?
Old Feb 13, 2010 | 02:15 AM
Jacksfirstdiesel's Avatar
Jacksfirstdiesel
a little more info would be helpful. If it's a dual mass flywheel the springs and the pilot bearing are typical problems. I had same problem but it was dependant on rpm. does it stop if you depress the clutch?
Old Feb 13, 2010 | 02:19 AM
Jacksfirstdiesel
can you feel it thru the shift lever?
Old Feb 13, 2010 | 09:37 AM
hoss95's Avatar
hoss95
ya u can feel it in the shift **** n i believe it does stop when i press in the clutch
