Start wire feedback?
Old Feb 12, 2010 | 07:39 PM
ri_truck_guy's Avatar
ri_truck_guy
Thanks....just wanted to make sure I wasn't drinking too much tonight...
Old Feb 12, 2010 | 08:23 PM
Franklin2's Avatar
Franklin2
Originally Posted by ri_truck_guy
I thought the brown/pink already spliced into the red/green after the resistor.
The brown/pink is connected to a set of contacts inside the switch that have power in the "start" position. Even though the diagram shows the red/lightgreen wire(which is hooked to the "run" position contact) is bridged internally to receive power in both the "start" position and the "run" position, I thought it would be extra insurance that the red/green did have power in the "start" position by jumping the brown/pink over to it right as it comes out of the switch.
Old Feb 12, 2010 | 08:28 PM
kjay's Avatar
kjay
This is good stuff, can I put the thread in reverse a tad to get instruction on how to wire the bosch relay that LCAM suggested I use to power the coil?
Old Feb 12, 2010 | 08:35 PM
ri_truck_guy
Pin 30 +12V power source
Pin 87 +12V to HEI
Pin 85 Red/Green wire from stock coil
Pin 86 To Ground
That should do it....
Old Feb 12, 2010 | 09:48 PM
kjay's Avatar
kjay
Thanks so much
KJ
Old Feb 15, 2010 | 02:46 PM
kjay's Avatar
kjay
Thumbs up
Hey guys, Just wanted to let you know I installed the relay last night and it works perfectly. No more Nascar toggle switch starting. Thanks for all the help.
Old Feb 15, 2010 | 03:03 PM
ri_truck_guy
You're moving right along on that truck.....
Old Feb 15, 2010 | 03:41 PM
kjay's Avatar
kjay
Yeah, when I look back over the past month I think I've accomplished quite a bit and it's been made possible for me with the help of you all at FTE. I've been dinking around with it since day one and for me, it's as fun doing the project work as it is driving it.
Old Feb 15, 2010 | 03:49 PM
kjay's Avatar
kjay
I originally bought it to do all the dirty work I didn't want to do in my '09. Basically a dump truck but I think it means a little more to me than that now. It's still going to be the little brother who gets the shaft on all the chores. I seem to look at it and feel about it a little differently since making it MUCH better than it was when I bought it.
Old Feb 15, 2010 | 04:20 PM
ri_truck_guy
Yes....everything changes with that sense of accomplishment....
Old Feb 15, 2010 | 04:32 PM
greyghost85's Avatar
greyghost85
congratulations, kj. keep us up to date on the ol girl
Old Feb 15, 2010 | 06:47 PM
kjay's Avatar
kjay
Sure will GG...... Thanks for the support
48prerunner
May 24, 2021 09:49 PM
Echotop
Mar 20, 2017 09:04 AM
78 Ford F150 460
38
Jul 28, 2015 07:51 AM
h-m
Feb 25, 2013 03:02 PM
Bruce C
Apr 2, 2005 10:54 AM
