No Start/Hpop
Old Feb 15, 2010 | 06:20 PM
  #31
medhvac's Avatar
medhvac
Originally Posted by tsmall07
Any updates on this?
nope not yet!Still waiting on my AE
Old Feb 19, 2010 | 09:00 PM
  #32
medhvac's Avatar
medhvac
still no update`s im waiting on my AE to see if it can help me?Been a week since i ordered it!lol must be back ordered.
Old Feb 20, 2010 | 11:07 AM
  #33
PaysonPSD's Avatar
PaysonPSD
Here's post #13 from the this thread but you may find it interesting. LINKYou can browse the rest of the thread from there.
Old Feb 20, 2010 | 06:28 PM
  #34
medhvac's Avatar
medhvac
Originally Posted by PaysonPSD
Here's is post #13 from the this thread but you may find it interesting. LINKYou can browse the rest of the thread from there.
thanks i did read that ,but hes truck would start!Mine died and would never restart,so im thinking if i keep cranking,and cranking the lpop isnt going to keep up because the engine isnt running?
Old Feb 20, 2010 | 09:21 PM
  #35
Kwikkordead's Avatar
Kwikkordead
Still not running?!?!?
Old Feb 22, 2010 | 06:00 PM
  #36
medhvac's Avatar
medhvac
still not running! I did get my AE today thanks CLAY,there was no codes,was able to buzz the injectors and hear them but the scanner said there was a unknown malfunction?Im just lost now
Old Feb 22, 2010 | 06:25 PM
  #37
Ponyboychris's Avatar
Ponyboychris
Did it originally slow down then die when driving? I wonder if your IPR isn't stick full of gunk. Just helped a member off the mountain this weekend and it was his IPR that was full of gunk. Just thinking out loud.
Old Feb 22, 2010 | 06:36 PM
  #38
medhvac's Avatar
medhvac
yes thats what the wife said happened!Yes i read that and was thinking how he knew it was his ipr?Well looks like i have to remove it and try to clean it!
thanks
Old Feb 22, 2010 | 07:49 PM
  #39
Ponyboychris
thanks
he went through the troubleshooting progressions and that's where it led him. He also had issues with the IPR before and when he cleaned it, the truck would run better. When it died this weekend, it was the first time that his truck flat out quit on him. He started loosing power, he put it in neutral to find a place to pull over and on decel, it quit. Couldn't get it started until he pulled the IPR and cleaned it. There's a tread that has the cleaning procedure: https://www.ford-trucks.com/forums/9...clean-ipr.html
Good luck.
Old Feb 22, 2010 | 07:55 PM
  #40
medhvac's Avatar
medhvac
sound like mine thanks ill try that sometime this week! Drive way mechanic here!lol
Old Feb 22, 2010 | 08:33 PM
  #41
F350-6's Avatar
F350-6
What else have you done with AE, Greg? After you hook up the scanner and go through the getting codes part, look near the top and you'll see a Live Data tab. Click on it and you'll see 9 boxes show up with a drop down menu below each box.
Select ICP PSI in one box, then ICP % in another. If you want, choose something for the rest of the boxes too, like RPM, EOT, Voltage, Injector pulsewidth, then after you've done that, try and start the truck.
Watch to see what your ICP psi gets up to while cranking and watch to see if the ICP % (IPR) increases and what it maxes out at.
Old Feb 22, 2010 | 08:42 PM
  #42
medhvac's Avatar
medhvac
man i tried that and my batteries were so low after playing with AE that it wouldnt turn over fast and would start to click!So i have it on a charger over night and ill try that later!
Old Feb 22, 2010 | 08:45 PM
  #43
Visseroth's Avatar
Visseroth
You guys are forgetting something............
Turn the key to the on posistion, step out of the truck and put your head under the truck and make sure you can hear the fuel pump, if you can't then chances are it's the fuel pump.
The reason I mention this is because you said that the truck slowly lost power which sounds to me like it wasn't getting fuel anymore.
Also you put oil in the HPOP and there was another post that states that it should have started for a second and it didn't.
Also you said there was no smoke which sounds to me as if the cylinders aren't being filled with anything.
Old Feb 22, 2010 | 08:56 PM
  #44
medhvac's Avatar
medhvac
fuel pump comes on i can hear it and feel it!yes no smoke while trying to start,yep i put oil in the hpop alot still no start!
Old Feb 22, 2010 | 09:14 PM
  #45
Visseroth's Avatar
Visseroth
ok, then put a pan under the fuel bowl drain hose and open the fuel bowl drain valve and turn the key on, make sure it's pumping fuel, it should come it as a nice strong steam.
