C6 Trans
Old Feb 10, 2010 | 04:09 PM
SmallBlockV8's Avatar
SmallBlockV8
C6 Trans
On a 1982 Ford Truck With a C6 Trans with overdrive, does the trans have 3 speeds including overdrive or is that without overdrive, I am trying to figure out if the overdrive isnt working. The truck is a 1982 Ford F-250 with a 302 and C6 Trans.
Old Feb 10, 2010 | 04:44 PM
Ford_Six's Avatar
Ford_Six
The c6 is a three speed transmission, no overdrive. If there is an add-on overdrive, that's a totally separate thing and shifted manually in most cases. If it's an overdrive auto, it's not a C6.
Old Feb 10, 2010 | 11:09 PM
85e150's Avatar
85e150
IF it's OEM, it could be an AOD according to this:
Ford Transmission Spotter's Guide .: Articles
IF it's an AOD, it is a 4 speed, and 4th is OD. It also has a locking torque converter, which will feel like another gear sometimes.
The AOD for that year is a troublesome transmission.
Note also on that link ways to ID your trans by pan size etc.
Old Feb 11, 2010 | 06:37 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It won't feel like another gear on an AOD. AOD was 60% lock and 40% slip anytime it's in 3rd gear and 100% lock when in 4th gear. It does not run unlocked sometimes and locked sometimes like the electronic transmissions do.
Old Feb 11, 2010 | 10:11 AM
85e150's Avatar
85e150
Thanks for the correction.
Dano78
15
Mar 25, 2011 07:22 AM
beartracks
Feb 25, 2009 05:42 PM
1stF250
May 25, 2008 09:42 AM
russell hanna
Sep 27, 1999 07:45 AM
