How do I find my engine build date?
Old Feb 10, 2010 | 01:10 PM
jfirstford's Avatar
jfirstford
The sticker on the inside of my driver's side door jamb shows a date of 02/04. But I've read many times in other threads that the truck's build date doesn't necessarilly give you a good indication of the engine's build date. I've looked on the FICM, but the sticker is gone. I've seen a recommendation to look on the passenger side valve cover, but all I see there is a red sticker with no distinguishing numbers and below that a sticker that is so wrinkled and degraded that there is no retrievable info.
So how do I go about getting my engine's build date from here?
I need some advice about tuners, guages, fuel supplements, egr, etc. And I want to make sure that I provide adequate info when requesting help or advice.
Old Feb 10, 2010 | 02:04 PM
Cowboy65's Avatar
Cowboy65
If all else fails copy down your VIN number and call Ford (800-392-3673). They will not give you anything over the phone but they will send you build information by mail (unless this has been discontinued).
Old Feb 10, 2010 | 04:27 PM
bpounds's Avatar
bpounds
If you have the original FICM on your motor, your engine build date and engine serial number will be printed on it.
Here is a post I made from some time ago:
https://www.ford-trucks.com/forums/8...ce-inside.html
If the sticker is gone, the serial number will be on the drivers side rear of the block. You might be able to read it with a small mirror. It will be tough.
Old Feb 10, 2010 | 04:39 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Isn't there something with the sticker color also? IIRC blue- which I have- is 03 motor. Didn't the sticker for early 04-up builds change to red?
Old Feb 10, 2010 | 06:17 PM
HeavyAssault's Avatar
HeavyAssault
My FICM was dated 2 weeks older than my truck...makes sense. The motors are not built in the KY truck plant.
Old Feb 10, 2010 | 10:59 PM
jfirstford's Avatar
jfirstford
OK, I gave it a try. The guy I talked to didn't have any new info for me, but he said he'd hand it off to research and have them call me back within 48hrs. So I guess we'll see.
Old Feb 10, 2010 | 11:07 PM
jfirstford's Avatar
jfirstford
I saw that post, but my sticker is gone.
I guess if the Ford 'research' folks don't come through, then I'll be trying to see the back of my block with a mirror and flashlight. Is this best attempted from above or below?
I don't know but mine is red.
Old Feb 11, 2010 | 09:19 AM
bpounds's Avatar
bpounds
I don't think there is any hope from the top. The bottom seems like the only way, and I don't know if it is possible.
Which label? I thought you said it was missing.
My FICM label has no color. Just a white sticker with black injet printing. I think you might mean the emissions label, which is on the passenger side valve cover. Mine is red. But it does not have the build date or serial number.
Old Feb 11, 2010 | 11:32 AM
jfirstford's Avatar
jfirstford
I don't think this is any hope from the top. The bottom seems like the only way, and I don't know if it is possible.
Well then, I sure hope the Ford 'research' guys come through.
My FICM has no label. It looks like there used to be one there, but it's gone now.
The red one I'm refering to is on the passenger side valve cover.
Old Feb 11, 2010 | 11:49 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Yes the sticker on the pass valve cover. I thought mine had a build date for the engine on it of 9/03 or 10/03. I will go check quick.
EDIT: Well, I was half right. It clearly says 2003 model at the top of the blue sticker, but no month. I guess I figured it was a late 03 engine due to the door sticker being early 04 (2/04 IIRC)
Old Feb 12, 2010 | 10:58 AM
jfirstford's Avatar
jfirstford
Got a call from a lady with Ford's Research Dept. She said that she couldn't find any info about my engine's build date. But she did provide me with my engine's serial number. I don't know if that will tell me much about the specifics of my engine, but I wrote it down anyway.
Old Feb 12, 2010 | 11:09 AM
brickie's Avatar
brickie
Where is your ICP,valve cover or under the turbo.It is on the valve cover so it is a late build you need all the parts for.IIRC the last of the 03s was put in on sept 29/03.
Old Feb 15, 2010 | 12:23 PM
jfirstford's Avatar
jfirstford
I appologize yall. I made a mistake. I must have seen an image of a red engine decal somewhere and got that stuck in my head.
My engine has a BLUE decal on the passenger side valve cover and has 2004 on it. But it doesn't specify the build date in terms of what month it is.
Check it out:
Old Feb 15, 2010 | 12:37 PM
jfirstford's Avatar
jfirstford
Does ICP mean Injection Control Pressure (Sensor)?
I don't know, but here's a picture. Maybe you can tell me:
Is it one of the highlighted yellow boxes in the photo?
Old Feb 15, 2010 | 12:55 PM
texans's Avatar
texans
yes it does and it is the one in the bottom yellow box. if that is your truck then you have a late build 03 or early build 04
